trans upgrade question
Old Jan 26, 2016 | 08:05 PM
hmer's Avatar
Default trans upgrade question
wanted to know if anyone can recommend any options for a replacement trany since its time for me to get it done ????
Old Jan 27, 2016 | 06:10 PM
Synthetickiller's Avatar
For an H2? If so, 2003-2007 or 08/09?
Your garage lists an H1 & H3.
Old Jan 28, 2016 | 03:29 AM
hmer's Avatar
Originally Posted by synthetickiller
for an h2? If so, 2003-2007 or 08/09?
Your garage lists an h1 & h3.
04 h2
Old Jan 31, 2016 | 12:01 AM
You could always drop in a 4L80. Should last a hell of a lot longer than another 4L65.
Old Jan 31, 2016 | 07:58 AM
jsbihn's Avatar
will the 4L80 work with the 04 computer and shift characteristics?
I thought I read the only trans that the earlier model h2s could take was the 65
Old Jan 31, 2016 | 12:16 PM
Only the 03 could?
If that's the case, you can possibly reuild your 4L65 or buy an upgraded 4l65.
Old Feb 3, 2016 | 02:19 PM
steve06's Avatar
Go to the internet and source raptor transmissions.. the will provide a tranny you will never have to worry about again. they can build to 750 hp...
Old Feb 3, 2016 | 05:10 PM
fnfal308's Avatar
I would be concerned more about torque in a heavy vehicle.
The 6.0 is not a torque monster, but the heavy hussy just doesn't move like a spring chicken and the 6.0 does like to move things. On the other hand it takes more power to move a 4l80.
I would go 4l80. And I will when the time comes.
Does the tcase mate up to a 4l80?
Old Feb 9, 2016 | 10:42 PM
yrkdmaxh2's Avatar
Transfer case should mate up to the 4l80, but it does rob more power than the 4l65, and IIRC the gear ratios between the 2 is also different.
If that's the case you may have to have someone do a "segment" swap with HP tuners where they change the TCM from the 4L65 segment to the 4L85 one.
If it were me I would just rebuild the 4L65 and use better clutch packs like the red altos.
greg260
Jan 27, 2018 12:41 AM
Dieseldrums
Jun 22, 2017 01:58 PM
eleewhm
36
Mar 16, 2015 06:43 PM
jasonsdad
Sep 18, 2011 09:32 AM
07HummerH3
Jan 6, 2008 05:52 PM
