Tranny acting funny
Old Feb 13, 2014 | 09:26 PM
1987c4red's Avatar
Default Tranny acting funny
2006 H3 rolling down the road 40mph thru about 60 mph with rpm at about 2000, the tranny feels like it momentarily slips. Tach will bounce 200-300 rpm below 2000 rpm. Is it my trans or an engine miss?
Old Feb 14, 2014 | 12:42 AM
happythree's Avatar
torque converter lockup happens around 40. sounds like something there is kicking in/out?
as you approach lockup, below that point,as you gently hit the gas you see rpm change quickly with no tranny shift.
when locked up above 40 the rpm changes slowly like in a stick shift in one gear. if you hit it too much it downshifts..
if you are on level road and holding steady on the gas, it should not change.
Old Feb 14, 2014 | 08:35 AM
Nmocean's Avatar
Mine was doing that right after I bought it with 42,000 on it. I took it back and of course they were not able to duplicate the problem but the guy said he knew what I was talking about. What I did was change the fluid and filter in tranny and installed an aftermarket cooler. It now has 80,000 on it and hasn't done it since.
Old Feb 14, 2014 | 09:14 AM
Full lock up is at 45mph. If you have a persistent hang up at lock up (a lock up that kicks in and out like it can't make up its mind, or unlocks after it did lock up without a change in throttle load and then takes too long to lock up again), you likely will need to have it looked at.
Diablito
Dec 12, 2012 11:20 AM
naluboy
Jul 27, 2010 11:44 PM
nyff395
Mar 13, 2010 08:18 AM
NIK1
Apr 29, 2009 07:54 PM
HummerUAE
Dec 13, 2007 02:27 PM
