TPM Questions
Old Dec 16, 2016 | 04:42 PM
Zero83's Avatar
Default TPM Questions
So i put a bigger tire on my factory wheel (2007 H3 Lux). The new tire has a max PSI of 80LBS. I have been running 50PSI for the last month and now that it got colder, im getting a service TPM on the dash. I did the reset thing where you key on and off headlight then deflate each tire and got the correct conformation signal each time. So im wondering, is 50PSI to much for the factory TPM or what? What are your thoughts?
Thanks.
Old Dec 16, 2016 | 05:47 PM
Paranormal's Avatar
I'am not sure about the TPM pressure reading but, why are you running such high pressure. I have 35" and keep them at approx. 32 psi. My TPM light has not come on. It is 20 degrees here today
Old Dec 16, 2016 | 06:16 PM
RKSmith163's Avatar
As indicated, it is a service problem and not a pressure problem. It's either lost it's programming or one has reached the end of it's life. Good Luck
Old Dec 17, 2016 | 06:41 AM
Dude, lower your air pressure to below 40psi. Your back and kidneys will thank you.
One of your TPMs has died. Time to replace one or more of them.
Old Dec 22, 2016 | 01:08 PM
Zero83's Avatar
Thanks everyone for the help. i will order new ones and have them put in. is there a way to test what one needs to be replaced?
Old Dec 22, 2016 | 01:15 PM
Bunger's Avatar
The tire shop should be able to scan for which one is not working.
These TPMS have a battery life of 7 to 10 years so if one has died, the others are not far behind.
Old Dec 30, 2016 | 09:27 AM
Cubeman's Avatar
hello , how do you service a TPM ?
Old Dec 30, 2016 | 09:45 AM
If it is dead, you service it by................ replacing it.
Old Dec 30, 2016 | 10:24 AM
Cubeman's Avatar
thank you Doc , I did find the thread on how to handle . I must have missed it on my search attempt . Thank you .
Old Jan 16, 2017 | 11:17 AM
Zero83's Avatar
Anyone know how to "disable" the TPM. Who needs to know there tire pressure anyways? lol
jm4490
55
Nov 8, 2015 06:24 PM
lucky19942001
Oct 18, 2014 09:39 AM
melvynray
May 11, 2010 12:45 PM
thunderwolf
Mar 24, 2009 06:30 PM
NoDakH3
Feb 13, 2009 09:08 PM
