tpm question
Old Feb 22, 2009 | 11:41 PM
lucky19942001's Avatar
Default tpm question
sorry if a repeat but any 1 no if the tpm's need to be reset after a tire rotation. having it done tomorrow at discount tire where i bought them and its free so going to them instaed of the dealer and wana no when i give them the keys if the tpm's need to be reset when they are finshed. i no they can do it cause when i bought new tires and they put them on they had to do it. so just dont wana give them the keys and have them assume and then be driving home and the tpm message comes on.
Old Feb 23, 2009 | 01:07 AM
Captkirk's Avatar
I just put new tires (including spare) on my 2006 H3 and had no problems at all with my TPMs.
I am not an expert but I would make sure they don't turn on the key at anytime during the tire change so it will never sense a low tire pressure.
Old Oct 17, 2014 | 04:42 PM
clean truck's Avatar
Default Tpms help
Tpms come on when I try to reset using matching procedure I get no response horn chips etc. the dic display the warning and the flat tire light flash correctly. Could this be a bad B C M?
Old Oct 17, 2014 | 06:18 PM
Happy Hummer's Avatar
Clean truck start from the beginning.
What was changed (if any)
What tires
What year
What size
Chris
Old Oct 17, 2014 | 06:21 PM
Old Oct 17, 2014 | 07:34 PM
RKSmith163's Avatar
Are all your doors closed when you initiate the procedure with the ignition and the headlight switch?
Old Oct 17, 2014 | 07:35 PM
norinco3264's Avatar
ROFL
Epic Necro bump..
While the issue has been brought up, I'd like to also say that my "Service TPMS" warning is on my DIC.
I have a 2006 Adventure model, 70,000 miles. This year I ran over an Electronic cigarette on the street and it pierced my new tire! (The Rage was strong that day)
I fixed the hole with a plug and a can of fix a flat into the tire. Didn't realize that I basically just destroyed the TPM sensor, because when I attempted the reset/relearn multiple times it kept failing on the Tire that I dumped Fix a flat into. Sad day.
Old Oct 18, 2014 | 09:19 AM
Two days before problem oil was change air presure test 2007 h3 Firestone tire 3700 miles on them 265 65 18 Thank Chris for any help you can give me. Ron
Old Oct 18, 2014 | 09:21 AM
Yes doors are closed parking brake is shown on dic
Old Oct 18, 2014 | 09:39 AM
You dug up a FIVE + year old post, whatever your question might be, it is unclear what it has to do with the OP inquiry (ie. Do you have to reset the TPMs after a rotation?)
The answer to the OP .... is no, you do not have to reset after a rotation.
Try a SEARCH, read what you find, then..... if you did not get your answer, ask a question in a NEW thread. Check this out, search results from this most incredibly difficult inquiry "TPMS reset" Hummer Forums - Enthusiast Forum for Hummer Owners - Search Results
jm4490
55
Nov 8, 2015 06:24 PM
bigshow1970
Jan 23, 2013 10:10 AM
jvorpahl
May 20, 2011 04:16 PM
melvynray
May 11, 2010 12:45 PM
NoDakH3
Feb 13, 2009 09:08 PM
