TPM Questions
So i put a bigger tire on my factory wheel (2007 H3 Lux). The new tire has a max PSI of 80LBS. I have been running 50PSI for the last month and now that it got colder, im getting a service TPM on the dash. I did the reset thing where you key on and off headlight then deflate each tire and got the correct conformation signal each time. So im wondering, is 50PSI to much for the factory TPM or what? What are your thoughts?
Thanks. |
I'am not sure about the TPM pressure reading but, why are you running such high pressure. I have 35" and keep them at approx. 32 psi. My TPM light has not come on. It is 20 degrees here today
As indicated, it is a service problem and not a pressure problem. It's either lost it's programming or one has reached the end of it's life. Good Luck
Dude, lower your air pressure to below 40psi. Your back and kidneys will thank you.
One of your TPMs has died. Time to replace one or more of them. |
Thanks everyone for the help. i will order new ones and have them put in. is there a way to test what one needs to be replaced?
Originally Posted by Zero83
(Post 341049)
These TPMS have a battery life of 7 to 10 years so if one has died, the others are not far behind. |
hello , how do you service a TPM ?
Originally Posted by Cubeman
(Post 341166)
thank you Doc , I did find the thread on how to handle . I must have missed it on my search attempt . Thank you .
Anyone know how to "disable" the TPM. Who needs to know there tire pressure anyways? lol
