Towing with H2
Old Jan 12, 2016 | 06:44 PM
mulepic's Avatar
Originally Posted by Max_09H2
I also towed a lot with my 04 Magnacharged H2 - a 23' boat in Arizona summers. It did fine. Just remember to disengage overdrive into a lower gear before the torque converter lock-up clutch disengages while in overdrive. Once the clutch disengages the torque converter starts making enough heat in low RPM overdrive to burn up any tranny. Problem is that RPM is too low to run enough coolant fluid through tranny in overdrive (since tranny oil pump is mounted directly on input shaft - more engine RPM is ne des for cooling)
I'm in AZ as well. I always think about adding a supercharger but it seems like a lot of times after someone adds a supercharger it brings up all sorts of other issues. Eventually it ends up for sale. So I'm very hesitant to pull the trigger on a supercharger. And our H2 is primarily used for towing the family camper, the last thing I need is to strand my family somewhere b/c the supercharger created some issue.
Old Jan 12, 2016 | 07:11 PM
ON IT's Avatar
from what im reading ... 100-180 ... 220 is warning .. 260 .. the fluid starts to break down and kill the trans.... I noticed when I jump on the highway and trans temp is still all the way cold ... it don't like to shift into overdrive... it holds the 3rd gear till it warms up a lil
scubagirl
Jan 4, 2021 11:10 AM
dave85c4
Mar 15, 2006 05:24 PM
usmcman001
Jan 26, 2006 05:38 PM
ty_r1
Oct 25, 2005 03:47 PM
Syd R
Oct 5, 2005 06:04 PM
