Torque converter info plz
Old Nov 27, 2014 | 07:43 PM
Nate2106's Avatar
Originally Posted by MVR 155
If you are planning to supercharge for sure later make sure to keep that in mind when you make your final decision to select a stall converter. The extra power/torque of the charger will have your converter flash higher. I personally don't think that running a higher stall converter on a heavy rig like this is a good idea, a lot of driveline parts that will see extra stress and if you tow there is going to be a lot of additional heat build up.
flash higher? I'm only going 300RPM's higher then stock. I do tow my trailer, so I will defiantly be looking into a better trans cooler to keep the heat down. Changing up the difs as well.
Old Nov 29, 2014 | 09:43 PM
woodwardsh3's Avatar
Most needs for a higher stall are due to a larger cam install. and you need a looser converter to allow the engine to idle in gear. your stall should be chosen to work the power band of your cam.
boman53
Apr 4, 2022 03:12 PM
EvanMEllison
Jun 2, 2014 06:25 PM
zachakamp
Mar 17, 2013 09:45 AM
BERULAKIDE
Dec 7, 2012 06:35 PM
mango
25
Jun 30, 2009 04:56 PM
