Tires Rubbing
Old Jun 20, 2011 | 09:17 PM
AzLegends's Avatar
Default Tires Rubbing
I have a 2007 Hummer H3 with stock rims and tires. I just had this problem pop up. When I turn the wheel sharply to the left or the right, the right front wheel will rub on something. Going in reverse is worse.
Any thoughts on what this could be?
Old Jun 20, 2011 | 11:33 PM
drtom's Avatar
Banned
u mite wanna turn sharply till it rubs,,,turn off your motor,,,put the e brake on.
get out and see whats rubbing
i think ure in a lock mode and hearing racket from the binding of the drivetrain
just guessin,,,stock wheels and tires dont rub
Old Jun 21, 2011 | 02:30 AM
AzLegends's Avatar
I had checked for rubbing previously and couldn't see it hitting anything. I checked and it was locked in 4wd, taking it out did the trick. I didn't even notice it, but the stereo installer must have hit it yesterday.
Thanks for your help!
Old Jun 21, 2011 | 12:00 PM
luda81's Avatar
wow I would have been so pissed. how did you drive home? and I hope nothing is damaged!
Old Jun 21, 2011 | 01:48 PM
08JJ's Avatar
Mine does that with 35's......it's the plastic piece on the rocker panel. I took the cap off the end and its much better now. I also had to remove my front mudflaps. My caster is extended all the way with alignment and the only way to fix is to shim the a frame and I am too lazy to rip into it.
Bedmison
Dec 9, 2014 11:47 PM
federicoiz
Nov 19, 2011 04:08 AM
novasaigo
Nov 18, 2011 03:24 AM
thehammer12
Jul 7, 2007 12:42 AM
07HummerH3
27
Apr 9, 2007 11:31 PM
