Temp Control Oddity
Old Aug 10, 2016 | 08:49 AM
bflank's Avatar
Default Temp Control Oddity
Since my H3 was new, while running A/C turning the temp control **** a couple of clicks from the full CCW position (cold) would result in a slightly less cold air flow. Just like you would expect.
Lately turning that **** even one click results in hot air blowing. Seems to me that the cause is likely to be:
1. Control module
2. Control ****
3. Wiring between 1 & 2
Any suggestions for troubleshooting? Any chance the recall wiring harness might help?
Old Aug 10, 2016 | 10:37 AM
1. Control module
2. Control ****
Yes, it includes the harness and resistor module.
Old Aug 10, 2016 | 10:50 AM
650Hawk's Avatar
The recall will not address the temperature control issue; it only addresses the fan speed. Here is the info you need on the temp control issue you are having: https://www.hummerforums.com/forum/h...p-28289/page4/
Scroll to post #18 for info on a Service Bulletin regarding the issue, and post #28 has info regarding an updated part number for the control module, but post #35 is where you start getting info on a DIY procedure on how to fix it.
Adrian Schoolcraft
Aug 8, 2017 06:27 PM
oceanbrave
Aug 6, 2015 03:55 AM
RadioMike
Jun 16, 2014 03:13 PM
maxwellmark
Jan 16, 2013 08:10 AM
Cube
May 10, 2012 06:41 PM
