Taking the back seat cushions out
Old Nov 6, 2006 | 04:43 AM
williecee's Avatar
Default RE: Taking the back seat cushions out
try a length of 2x4 with all edges beveled, holes drilled @ all posts, and use the nuts upside down with a fender washer for adjusting the height. Also cover with I/O carpet. Screw some spacer blocks to the bottom to keep it stable. this should be a quick and cheap do.
Old Nov 6, 2006 | 04:48 AM
williecee's Avatar
oops --- screw the nuts all the way down, slip the 2x4 over the posts and adjust the nuts if needed then set the adjusting blocks.
Old Nov 6, 2006 | 04:04 PM
HummerMike's Avatar
Nice job mike. I really do wish GM would consider making everything flat like every other mid sized SUV on the planet. But then again, I wouldn't want to loose anymore ground clearance underneath.
Old Nov 6, 2006 | 09:20 PM
HummerGuy's Avatar
ORIGINAL: dilo2001gt
How did you get the H3 sticker to stick on the headrest mine would not.
I cleaned the back of the headrest off with a vacuum, scrubbed it clean, and then used duct tape to take off all the extra lint. Then I very carefully placed them on the back of the headrest and smoothed them off with my finger just enough to make them stick. Eventually the adhesive sticks to the fabric. I think it just takes time for it to settle in there. If you just squish them on there, they will bend and fall right off.
Thanks for the advice willie. I think I'm going to do that. I'll probably go pick up a 2x4 or even a 2x6 and make that little rest. I hope that doesnt make an imprint in the entire seat lol.
I know what you meant about the indentation skeet. I am aware of that. I was hoping it would come out after I'm done but it doesnt look like it's going to huh? I wonder if you soak it with cold water and take a dryer or a heat gun to it if it will shrink back into place. It's a long shot but worth a try. Although you could burn up your fabric.
Old Nov 6, 2006 | 11:12 PM
Dennis's Avatar
Looks to me like you could lay a 2x6 across that area and just drill out for the studs..Surely Mike, at your new house there is some scrap lumber laying around.
Old Nov 6, 2006 | 11:15 PM
Dennis's Avatar
Oh..Another thing..Your door jam at the fender flares are looking a little funky..thought you might have missed that during your last cleaning....
eh..My pleasure[sm=pimp.gif]
Ghostrider
Feb 6, 2007 01:03 AM
Sugardaddy
Nov 6, 2006 03:51 PM
Injunfarian
Sep 26, 2006 02:07 AM
skeeet
Sep 23, 2006 12:18 AM
efrainl956
Sep 6, 2005 04:50 PM
