Stering wheel lights
Old Mar 14, 2013 | 08:08 PM
JCsh2's Avatar
I looked on Ebay is these the bulbs i need? 3mm 60ma 0.060A Wire Terminal, Size T-1
Ratings:
12V 0.060a 60ma
Brightness: 0.15CP @ 12V
Bulb width diameter: 3mm with minor variation
Bulb Height 6.3mm with minor variation
Wire Lead Length: 24mm average (if you need longer please contact us)
The bulbs are equivalent to Radioshack Bulb 7219 and Radioshack Bulb 272-1092
If you need bulbs that are rated at 14V please see my other listings. This is NOT LED
The 12V will burn brighter at 14V, at reduced bulb life
The 14V will burn dimmer at 12V, at increase bulb life
This listing is for 12V Bulbs 60ma also known as 7219
These bulbs is commonly found behind many switches and buttons
--VSC Button
--Cruise Control Button
--Hazard Button
--Clock Bulb
--Sunroof Buttons
--Please remove the bulb first and match it with the photo.
--Bulb should measure 3mm
Old Mar 15, 2013 | 06:13 PM
LoJac963's Avatar
I believe those specs are correct.
Old Mar 16, 2013 | 04:44 AM
JCsh2's Avatar
Ok thanks for your time and have a good one.
spusoccer
Jun 24, 2012 08:02 PM
jamdd2005
Aug 12, 2011 11:30 AM
davyo
May 12, 2008 11:38 PM
BahamaTodd
Jan 25, 2008 03:48 AM
