Slight grinding noise when turning right...HELP?
Old Sep 15, 2013 | 07:30 PM
Kirkhayes37's Avatar
Ok, I tore into this problem this weekend. It never ended up being the hub assembly/bearings. I ended up swapping the front tires and for some reason, I cannot explain....but it is quiet as a church mouse now. I did ended up swapping out the brake rotors because one was very rusted and pitted. My Hummer came from Sioux Fall South Dakota, and I can see it hit the streets a lot while they were salted in the winter.
But the growl/grind did not go totally away until I swapped tires. Drove it all weekend and it is nice and quiet turning both ways. Weird.
Old Feb 4, 2014 | 04:01 AM
jasminerobert's Avatar
Sounds like a steering ball joint is worn, or it could be a defective wheel bearing - if you jack the wheel up off the ground and put it on an axle stand, you can then shake the wheel with a hand top and bottom, and then side to side.
windycitykid
Jan 12, 2015 07:18 AM
jasonomni
Nov 7, 2014 05:29 AM
force0009
Mar 16, 2014 01:15 PM
Mros814
Oct 23, 2012 02:48 PM
bimmen04
Aug 29, 2010 12:26 PM
