Side Marker light removal
Old Aug 4, 2008 | 01:30 PM
motley1987's Avatar
Default Side Marker light removal
Has anyone removed the side marker lights? Do you have to go in from under the wheel well? There's a plastic fastener there but I'm not sure if that's the way in. There's some give pulling them out from the outside, but I don't want to tug too much and have to replace them if it breaks.
Old Aug 4, 2008 | 02:30 PM
Dennis2's Avatar
Default RE: Side Marker light removal
From all that I've seen about them, you have to go after it by removing the wheel well liner.
Old Aug 5, 2008 | 02:09 AM
mountainbiker's Avatar
Yes, you get to them by removing the wheel well liner. What is your end goal? In Europe, we need to have activate side indicators, so I had to add a bulb and tie them to my turn signals. If you buy a European-spec (i.e., a SA produced H3), this is standard already.
Old Aug 5, 2008 | 06:02 PM
empoer sztoid's Avatar
When I removed my side maker light lensesto put the clear chrome ones on,i went in from the front. To me it seems a whole lot more easier to remove the grille & headlight housingcause I have more room to work with as oppose to working through the wheel well. Then again I never tried it.
Old Aug 5, 2008 | 06:49 PM
motley1987's Avatar
I saw someone in the forum smoke their marker lights and thought it looked cool so I thought I'd try it.
Old Aug 9, 2008 | 01:04 AM
alrock's Avatar
Try this https://www.hummerforums.com/m_69776/tm.htm
or this
https://www.hummerforums.com/m_75638/tm.htm
Very easy to go in from the wheel well liner. Just pop the center of the fasteners and pull back about 1/2". At that point the fastener is easily removed from the liner. Once you figure out the first one it'll only take a few minutes to get the rest.
CRXMA22
Oct 2, 2020 06:23 PM
Hummerhead
27
Aug 14, 2011 10:34 AM
HummerGuyCMH
May 30, 2011 10:49 PM
Autobot85
Aug 1, 2010 03:38 PM
IYF_H3
Nov 7, 2007 01:51 PM
