Shiny spot
Old May 17, 2019 | 11:26 PM
nyparrothead's Avatar
Default Shiny spot
Hi all
today I noticed a shiny spot on the pass side of the sway bar. I turned the wheel hard left and the was 3/4 in space between the tire and row spot but it had to be the tire that did it. I am running stock wheels and tires and the suspension feels tight and there is only 48k on the truck..... any ideas
mark
Old May 18, 2019 | 08:18 AM
Sway bars can get off center and shifted some to one side or the other.... I'd check that it is centered right. Another possibly is that it might only get rubbed slightly under some specific articulation. For example if your driveway is on a hill and meets the street at a fairly sharp change in angle right when you are cutting the wheel all the way backing out or something like that.
Old May 19, 2019 | 09:44 AM
LoJac963's Avatar
That is true, mind did the same thing before I started upgrading the front suspension. When I did that I made sure I centered the sway bay.
jman1335
Oct 20, 2016 12:04 PM
TheH2
Jan 8, 2015 01:35 PM
gowpowdsp
Aug 17, 2012 09:16 AM
2wheelmonster
Nov 15, 2009 06:16 PM
skeeet
Nov 10, 2006 08:41 AM
