Angled Tire After Full Turn
Old Oct 20, 2016 | 10:27 AM
jman1335's Avatar
Default Angled Tire After Full Turn
Just a quick question: I noticed the other day that when I fully turn my tires to the right on my 2008 H3 Alpha, the wheel is not "vertical," i.e. the tire seems to be on a 70 or 80 degree tilt. Is this normal?
Also, it looks like on both sides, there is a "clean" part on a metal bar (part of the steering/ suspension system), which I'm thinking is when I do a full turn, the wheels actually contact with it briefly.
I get the well-documented "parking lot shudder" when I'm in an underground parking lot and try to do a full turn....the studdering and screeching of the tires.
My tires are 285/75/R16 (which is a slight tad bigger than the 265's that came standard on the truck with the first owner).
Looking for any feedback. Thanks!!
Old Oct 20, 2016 | 10:43 AM
A pic would help, but at full lock your steering geometry will tilt the wheels/tires some from vertical.
Your wheel isn't touching the sway bar, your tires can at full lock turn. Solution = do not turn so sharp.
The H3 has a tight turning radius for navigating off road obstacles. No need to wrench the steering wheel that far in parking lots or on the pavement.
Old Oct 20, 2016 | 10:47 AM
jman1335's Avatar
Ya, I figured it was "normal" due to offroad capabilities, but just wanted to check. I know its a heavy vehicle and was just worried that if the wheel is at 80 or 75 degrees (instead of 90), something might give with all the steering and suspension.
I try not to turn sharply but in tight urban environments and stupid parking lots with tiny spots, it gets tough.
Thanks again!
Old Oct 20, 2016 | 12:04 PM
happythree's Avatar
tires screach on tight turns because each side of the tire is moving at a different rate, just like left and right tires turn at different rates on turns depending on the surface. smooth asphalt, hold your ears!
u dont notice on snow, wet roads.
Joseph Pellegrino
Oct 5, 2015 10:50 PM
4u33er
Sep 16, 2013 11:13 AM
RKSmith163
Dec 9, 2008 08:20 PM
ccorah
Jul 4, 2007 12:17 AM
littlehummerboy
Feb 16, 2007 06:00 AM
