View Poll Results: Do you rotate your tires?
Yes
69.23%
No
7.69%
Sometimes
23.08%
Voters: 13. You may not vote on this poll
Rotating Tires Poll
Old Oct 16, 2015 | 06:54 PM
Synthetickiller's Avatar
Default Rotating Tires Poll
I was in the process of rotating my tires today. It takes a long time w/o a lift!
I was thinking about how much I rotated my tires on my original H2 & realized I never did and got 90k miles out of the stock BFG KOs. I only had new tires mounted b/c of the visible cracking (mostly from daily sun damage over 5 years) . They were probably good up to 100k miles or more, especially if the H2 was garaged.
I realize all literature on tires states to rotate every 5k to 8k miles (or whatever the manual/tire manufacturer states), but I'm wondering if this is something people on the forum actually do.
Going through the process of rotating all 4, plus reprogramming & re-inflating each oil change is a lot of time spent, especially if it, say, only gives me 110k miles vs 100k miles otherwise.
What do you guys do?
Old Oct 17, 2015 | 07:44 AM
calif phil's Avatar
I do mine at every oil change. I do it myself so I am not out any money. My '06 doesn't have a TPMS to reprogram. 100k miles is a lot. I doubt I will get that many.
Old Oct 19, 2015 | 10:52 AM
Bunger's Avatar
I rotate my tires at the same time I do an oil change.
I don't include the spare in the rotation so I never have to recalibrate the TPMS system.
Old Oct 21, 2015 | 02:23 AM
hummguy's Avatar
I'm rotating the tires every 5k miles, but I don't include the spare.
Old Oct 22, 2015 | 07:19 PM
SGME9's Avatar
I rotate every 5K. Discount tire does it for me no cost.
Old Oct 23, 2015 | 02:31 AM
LoJac963's Avatar
I rarely rotate my tires which is just plain stupidity on my part. I have rotated my new tires more often than the stockers but that's because the MT's get chewed up must faster on the fronts.
I also had the broken stud issues last time I rotated so that has left a bad taste in my mouth. Something as simple as rotating tires turns into a pretty decent project when studs break and they have to be replaced.
Old Oct 23, 2015 | 10:47 PM
When I had my 03, I should have.
I'm still amazed they lasted so long.
It's a royal pain w/ the 2009. After swapping, you have to reset the TPMS by deflating each tire individually, then refill to the proper PSI. Without a lift, it tedious to say the least. With 2 jacks & an air compressor, it still takes more than an hour to do. It's 15 minutes just to loosen all 32 lugs.
Old Oct 24, 2015 | 10:16 PM
honda400ex2003's Avatar
I try to do every other oil change in the cars but since I have boggers on my h2, I've never done them.
Steve
jamesb1516
Nov 18, 2014 06:07 PM
khoolhandz
64
Nov 18, 2006 01:14 PM
bucsfan
Sep 2, 2006 03:06 AM
importkiller
Aug 27, 2006 11:27 PM
importkiller
Aug 3, 2006 09:07 AM
