Road trip .. Need urgent help
Old Jan 1, 2017 | 09:19 AM
H2Miami's Avatar
Default Road trip .. Need urgent help
I'm 900 miles from home and just found out the Y connecting 3 antifreeze hose is leaking .
Nothe a crazy Leak but a few drops were on for and a few more under the truck
I'm guessing the problem was caused by using the heater which I never use in miami
I don't see any clamps on the Y . How is it supposed to be replaced .
I'm not sure if should hit the way back as is .
Any one know the part number
Update: researching online show as the past needs to be replaced with the hose. So not disconnection from the Y .. could anyone clarified
Old Jan 1, 2017 | 10:42 AM
tharber's Avatar
Its a quick disconnect coupling. It should have tabs to push to remove hose from Y.
I would pull into somewhere and buy a copper T fitting and 3 hose clamps to fix.
Its part PART#: AC18221L
Tim
Old Jan 1, 2017 | 01:53 PM
H2Miami's Avatar
Tim
Just stopped in Autoze (was open Jan1 )
They show me the Oem Y s fixed . No way to replace only the Y . So in my opinion it is the plastic cracked or tye hose got a hole
Bought the aftermarket for $90 which comes with the 3 hoses with clamps and the heater hose connector that goes thru the wall and yes that connection s like the one used.for gas lines Plus 3 gl of antifreeze
Looks like an easy repair . Will do it tomorrow morning before leaving TN
Thx
Old Jan 3, 2017 | 08:11 AM
calif phil's Avatar
Using the heater will have no effect on that going out. If it's just a few drips wait till you get home to replace it. Cold weather is probably what caused it to leak, seals and O rings shrink in the cold and will leak or seep.
Old Jan 3, 2017 | 06:48 PM
H2Miami's Avatar
After reading some horror stories I decided to Replace it in the morning before hit the road .
Was easy . But couldn't remove the heater hose from the wall . Need a tool from napa to remove the clip .
So I cut the oem and attached to the Y
An inspection on the Oem Y didn't show any crack but it was leaking everytime more .
Btw the Y with 3 hose cost $90 in Autozone .. It is only $37 from Amazon
H2Miami
Jul 31, 2022 08:58 PM
H2Miami
Oct 11, 2013 08:33 PM
raptor0690
Sep 19, 2009 11:27 AM
RyanCodyH3
Jun 9, 2008 09:56 AM
pgaduane
24
Nov 26, 2007 07:17 PM
