Right front rattle
Old May 9, 2007 | 12:57 PM
msl369's Avatar
Default RE: Right front rattle
I noticed a while back i was getting a rattling/wind noise in the cabin. Took it to the dealer they claim to have fixed it... of course it was way worse and I realized that driving it out of the dealership. My repair worked awesome, I took the interior/cabin light down and placed 4 squares of material as far back, foward, left and right of the opening (the light was in). The material I used was from an old foam bed liner(ie; memory foam, egg crate style stuff). It worked awesome noice reduced by 98% no problems since. The only noise I still have is when travelling upwards of 70mph. That noise is coming from the molding around the driver's seat belt. The sound is the two pieces of plastic molding rubbing togethor, one day in the near future I plan on taking it apart and seeing whats causing this and fixing it.
The best way to find the source of the noise is to get someone who cares as much about the problem as you and have them ride shotgun while you drive and have them locate the problem.
Old May 9, 2007 | 01:23 PM
bobopotato's Avatar
Check your front wheel well, during one of the off-road trips, I must have hit something that cracked that rubber-like trim in the wheel well. When going on the highways, the wind makes the thing flap a little that sounds like a rattle. Glued it back together since and no sound!
Old May 9, 2007 | 05:30 PM
grosen's Avatar
Thanks for the info. I'll check it out!
Old May 29, 2008 | 12:38 PM
majabu's Avatar
Not sure if I have your problem or another one. I've had it in the shop a half dozen times as well. At low RPM when I hit 10 to 15 miles per hour I get a short vibrating sound. I can sustain it if I keep at that speed but seems to go away after I've driven for a bit. The noise seems to be coming from the right hand side of the dash. Mine is a 2006 H3. Any help would be appreciated. I go crazy for rattles and vibrations and I've had this one for two years. Thanks in advance.
Old Oct 7, 2008 | 06:51 AM
Hamidaddin's Avatar
ORIGINAL: grosen
I know it's been awhile since this was posted, but I was having a similar problem. I had the H3 in the dealership over 6 times. They heard it as well on test drives. Happened at highway speed on windy days.
The issue is the plastic moldings on either side of the windshield. The sun seems to warp them over time. Dealer switched them out and they were ok for alittle while and then it began again. I've contacted GM and they are aware of it, but that doesn't mean anything will be done. Looks like just a bad design, but the sound it annoying.
I had the same problem and it was really annoying when driving the car in highways in windy days. Anyways, I took it to the dealership and as grosen said, the problem was the plastic moldings in the upper corners. They didn't change them for me, they just filled the gaps with black silicon to stop the the air from going through them and making the annoying wind sounds.
Old Oct 15, 2010 | 02:23 PM
PhenyxH3's Avatar
Originally Posted by dilo2001gt
nah Pantera is better
I second that
dmb7280
Nov 16, 2014 03:38 PM
Hummer2006h3
May 30, 2011 02:01 PM
haiminger
Jan 24, 2008 11:48 AM
07TacticalH3
Nov 10, 2007 05:46 PM
gericoshep
Oct 17, 2007 06:32 PM
