rear axle drain plug seepage
Old Mar 20, 2008 | 12:41 PM
josh1899's Avatar
Default rear axle drain plug seepage
Ok, Ok, I've searched, and can't find anything definitive. I changed Diff. fluids a few weeks ago, and my rear is starting to leak slightly around the drain plug. Maybe a few spots a day. I tried to tighten plug, but it is on tight. I'm wondering if I needed to use a new crush washer or something when re-installing the new plug. I asked Gene, and his computers don't show anything. Any ideas to stop the leak?
Old Mar 20, 2008 | 01:56 PM
Default RE: rear axle drain plug seepage
Josh, is it at the fill plug, or a drain plug?
If it is seeping at the fill, it might just be overfilled a tad, won't hurt anything. You can take out the fill plug, while on level ground and let the extra diff. fluid out.
If at a drain, you can try thread tape at the outer threads and see if that seals it up for you. You do not want any thread tape to get inside the diff.
Hey, how about a pic, then someone can for sure help you.
Old Mar 20, 2008 | 02:19 PM
josh1899's Avatar
Doc, It's the drain plug. I just wiped it off this morning, but once it starts again, I will take a pic. Where can I get thread tape, and how is it applied?
Thanks again,
Josh
Old Mar 20, 2008 | 02:25 PM
josh1899's Avatar
Never mind, Googled it! I guess I'll try this, but from what I've read, it's painly for PVC and plumbing. Will it work as well on metal to metal surfaces? If anyone knows any other fixes as well let me know!
Old Mar 20, 2008 | 02:37 PM
I have used it on everything immaginable, from irrigation pump plugs, differential plugs, you name it. Just to make sure, I am talking about (white) teflon thread tape, I would not recommend any paste or putty.
Old Mar 21, 2008 | 07:28 PM
gmpartsdude's Avatar
I too recommended the teflon tape. If not, go to the hardware store and get an o-ring to fit on the end or something.
Old Mar 22, 2008 | 08:44 AM
Muddydawg75's Avatar
Does the 3 have the 3/8" drain plug or is it a bolt?
I can't say I've ever seen a plug leak...
Old Mar 22, 2008 | 10:52 AM
josh1899's Avatar
3/8" drain plug.
DOC4H
Aug 16, 2017 07:59 AM
travieso
Jul 28, 2013 04:42 PM
rushl
Apr 16, 2011 09:41 AM
Broken Halo
Mar 7, 2010 08:02 PM
drhodgie
Jun 22, 2009 10:20 AM
