RANCHO VS TUFF COUNTRY
Old Feb 22, 2008 | 10:55 PM
w3sCiH3's Avatar
Default RANCHO VS TUFF COUNTRY
What do you Perfer?
Old Feb 22, 2008 | 11:50 PM
rhill20's Avatar
Default RE: RANCHO VS TUFF COUNTRY
Are you talking about the shocks or the lift? Another member on here checked into the Rancho (I think) lift and found that it won't work on the H3 as of now.
Old Feb 24, 2008 | 09:52 AM
Bennersj's Avatar
I may actually have something to contibute to this one, just spoke with both the Rancho and Tuff Country reps yesterday.
After speaking with both, my personal pref. would be the Tuff Country and my reasoning behind that is that the Rancho lift DOES require cutting of factory brackets in order to install. Neither one requires any kind of welding. If you do not want to have to cut go with Tuff Country if your not worried about that then it is again a personal pref.
Old Feb 26, 2008 | 12:09 PM
w3sCiH3's Avatar
I read couple of Ranchos specs also Tuff. Rancho can fit up to 37" and Tuff only 35" so how is that you both have 4" lift but Rancho clears more?
Old Feb 26, 2008 | 08:02 PM
Bennersj's Avatar
just looked at the Tuff Country spec and pricing sheet they say they will fit a 36" tire. BUT after speaking to both the Rancho and Tuff Country sales reps at a show this past weekend neither would recommend the 37's both said the truck doesn't have the power (they were on both show trucks 37's) Go with 35's
Old Mar 2, 2008 | 09:48 PM
w3sCiH3's Avatar
i cant find a 35" tire that fits a 24" rim. Well I have the 3.7L motor, plus 5 speed standard so more power handling, you think ill be able to pull it off?
Old Mar 4, 2008 | 10:32 AM
TheGunnyRet's Avatar
ORIGINAL: w3sCiH3
24" Rims are pretty big but here you go found this for you:
http://www.kumhousa.com/tires/light-.../KL71/specs.do
Toyo Open Country A/T LT325/50R24P/N-301450 Rim Width-9.0-10.0-12.0Dia-36.7
Old Mar 5, 2008 | 03:36 PM
w3sCiH3's Avatar
Theres not that much lifted Hummer Here in Hawaii, and pictures on the internet dosn't show much, what do you think i should go cause im going with a 4" Tuff Country Lift and I want Asanti Rims either , the Rims size range from 19"-24" and also what size and stlye tire should i get?
http://www.sleekmotoring.com/images/asanti/AF143big.jpg
Old Mar 5, 2008 | 04:42 PM
Bennersj's Avatar
If you plasn on going off road I would highly recommend not going with anything bigger than the 19's and that is kind of big.
smpfalzer
Apr 12, 2012 03:28 PM
brachilius
Aug 25, 2010 08:24 AM
TShepp
Jan 17, 2010 10:42 AM
southernH3
Nov 18, 2009 03:38 PM
Black.is
Oct 13, 2007 05:47 PM
