Radar Dector
Old Feb 24, 2006 | 07:04 PM
LostOne's Avatar
Default Radar Dector
I am looking into hard wiring a radar dector in my H3. The dector is located right above the rear view mirror and thinking the wire will come down on the driver side. Looking for a wire that I can tap (or better yet maybe ther have a spare wire under the dash) into that will go off when the H3 turns off.
Old Feb 24, 2006 | 07:35 PM
G Man's Avatar
Default RE: Radar Dector
I hardwired mine off of the fuse box. I think the purple wire is ignition, and the one I used. Check with a test light just to be sure.
Old Feb 24, 2006 | 08:44 PM
LostOne's Avatar
How did you get to the fuse box from under the dash?
Old Feb 25, 2006 | 01:31 PM
G Man's Avatar
ORIGINAL: LostOne
Obviously, as you know, the fuse box is under the hood. I went through an existing rubber gromet in the firewall.
Old Feb 25, 2006 | 04:59 PM
dilo2001gt's Avatar
How did you put on the windshield when it flat
Old Feb 25, 2006 | 05:53 PM
G Man's Avatar
ORIGINAL: dilo2001gt
Most radar detector mounts have a thin metal bracket, with suction cups. The metal bracket is very easy to bend to the angle needed. At least that is the way it is on my Escort 8500.
Old Feb 25, 2006 | 08:29 PM
dilo2001gt's Avatar
I bought one but it would not bend so i return it.I want to get the battey one that clip to the visor
The Escort solo.
This past thursday had to go to court to fight a ticket
he said from a on ramp with in 1000 ft i was going 83 ya right that under porwed motor
so from 10 mile i got to 83miles in 1000ft i could see that if i was in the mustang
oh well i was not guilty
Old Feb 27, 2006 | 10:42 PM
LostOne's Avatar
Well I got the Radar Detector install...all wires out of the way now.
I pulled a set of wires from the engine area to under the dash via the Hood release cable race way. Then installed the ground wire onto the grounding bar next to the fuse box on the side wall. Install the hot wire on to #4 fuse (Roof Lamp) so when you turn on the H3 the Detector comes on and off when it is off. The wire for the detector to under the dash was easy to hide...just slip it uner the headliner and then down the side door plastic.
Old Feb 28, 2006 | 09:56 AM
dilo2001gt's Avatar
ON SOME H3 YOU HAVE TO BECAREFULL ON THE PILLERS SOME HAVE AIRBAGS IN THEM ON THE ROUND CIRCLE ON THE PILLER IT WILL SAY AIRBAG
XJEEP-GIRL
Mar 7, 2010 02:53 PM
jake1z
Feb 18, 2010 05:35 PM
berniedap
May 14, 2008 09:59 PM
Doc Olds
Dec 16, 2007 04:08 PM
audil
17
Sep 22, 2007 01:04 AM
