Radar connection
Old May 14, 2008 | 10:26 AM
berniedap's Avatar
Default Radar connection
Hello All,
A forum nubie.
I'm looking to connect my RX65 radar detector to a switched hot line in the compartment that houses the sunroof, map lights, etc.
I've tried using the orange line going to the sunroof along with the black line going to the same switch but when I turned the key on the sunroof vented. Obviously not what I wanted.
Can someone direct me to the proper hotwireand ground wire I can use to accomplish this?
Thanks!
Oh yea, I have a 2006 H2
Thanks!
Old May 14, 2008 | 10:58 AM
blackstangs281's Avatar
Default RE: Radar connection
First off...........Welcome!
As for the radar detector, I just ran the wire across the top of the window, under the piller trim, and into the fuse box. You can ground it right there also.
Old May 14, 2008 | 12:00 PM
Lampooner's Avatar
Also interested in which wire for switched 12 VDC. I have a couple of things to mount that need power - rearview camera & GPS.
Thanks in advance.
Old May 14, 2008 | 12:35 PM
HumminNBoatin's Avatar
You need to tap into the Hot wireBEFORE it reaches the switch. And Check to make sure that you are truly grounded. It sounds to me like you tapped into 2 power wires.Let me explain:
If your supposed ground is really a hot you are letting power come into the vent motor and bypassing the switch. Move you ground.
I installed my XM radio up there and everything works fine for me.
Old May 14, 2008 | 05:24 PM
SafariHummerH2's Avatar
Hello friend,
With an inexpensive 12 volt light tester you can find a "switched fuse".
Just touch each fuse top with the tester and each time you turn your ignition key to the accessory position.
If the tester lights when you turn your key to the accessory position, then you've discovered a "switched fuse".
Just run the wire across the top of the window, under the piller trim, and into the fuse box. You can ground it to the vehicle chasis right there also.
[IMG]local://upfiles/4067/B4AA43F1FC4F421A858BCD67C95A3C95.jpg[/IMG]
[IMG]local://upfiles/4067/D9810E22E06947379753274EA2C02153.jpg[/IMG]
Old May 14, 2008 | 09:59 PM
dizzy's Avatar
I tapped my back-up camera into the fuse for the rear wiper so I could have the camera on whenever the truck is on.
kurteken
Nov 16, 2011 02:31 PM
mattp_160
19
Oct 7, 2011 11:26 AM
CarlosC
Sep 21, 2007 01:17 AM
Texbow
Sep 17, 2007 02:46 PM
IYF_H3
May 16, 2007 04:35 PM
