Hard wiring radar detector and gps
Old Feb 17, 2010 | 05:30 PM
jake1z's Avatar
Default Hard wiring radar detector and gps
Just got an 08 h3 last week and it does not have a owners manual in it(ording one off ebay) Is there a fuse box inside the truck or only in the engine comparement? i have the kits to hardwire my stuff using a fuse socket in a fuse box. thanks
Old Feb 17, 2010 | 05:59 PM
Broken Halo's Avatar
There is only one fuse box and it's located under hood, forward of the battery. Be careful removing the cover, as many people, (including myself), have broken the release tabs. Inside, you probably have 4 unused fuse holders (these are for accessories such as optional roof, and grill mounted lights). One of these will operate with the ignition key in on/run. This is the one I hooked my GPS up to. You'll need to use a multimeter to test for the correct one. The others have constant power. I ran my wire thru the firewall, thru the grommet that is for the hood latch release cable.
Old Feb 17, 2010 | 06:20 PM
Here's an advance copy '08 owner's manual for you
http://www.gm.ca/media/owners/manual...nual_en_CA.pdf
Old Feb 18, 2010 | 04:28 AM
Daytona Hummer's Avatar
Why not splice into the power to the cigarette lighters? Pull the cover plate forward to expose the back side connections.
Old Feb 18, 2010 | 07:54 AM
D VADER's Avatar
Is there any power at the mirror/OnStar system? That's how I wired my CTS. Cool having the radar next to the mirror where the windshield is tinted and you can't see the detector from the outside.
Bob
Old Feb 18, 2010 | 02:41 PM
Bunger's Avatar
Be careful with hardwiring the GPS. Many of them do not operate on 12 vdc. They have a voltage reducing circuit built into the cigar plug which drops the dc down.
My Garmin runs on 5 vdc. If I direct wired it, it would fry.
I got around that by direct wiring a cigar receptacle up under the dash and plugging in the Garmin cigar plug into it. The whole thing is tucked up hidden out of the way.
Old Feb 18, 2010 | 03:15 PM
JGBB04's Avatar
Bob
Yes there is
Old Feb 18, 2010 | 05:13 PM
Guess I should have clarified that. I did the same thing with the cigar lighter under the dash, I just ran the 12v feed for the cigar lighter to a key operated open fuse in the fuse box. Now my Garmin turns off and on with the ignition.
Old Feb 18, 2010 | 05:35 PM
jake1z's Avatar
i bought hardwire kits off ebay... they are made to hook into the 12 volt system... ran the wires for the radar detector today waiting on the gps kit to get here.. thanks guys
XJEEP-GIRL
Oct 1, 2012 10:42 AM
mr.spooky
Dec 22, 2011 06:43 AM
XJEEP-GIRL
Mar 7, 2010 02:53 PM
bonzaiii
Jan 30, 2008 11:03 AM
LostOne
Feb 28, 2006 09:56 AM
