Please need your help
Old May 26, 2009 | 12:34 AM
Bo's Avatar
Bo
Default Please need your help
Hi guys,
I need your help. I have noise comming under the car and allover the car - only when the temperature is under 60F. It sounds like driving old car. If the temp is higher than 60F the noise disappears. I took the car to the service, but they didn't hear anything because it was warmer than 60F outside. They lubed everything but the noise is still there. It does it especially when going over bumps or when turning. Any advice? Does anybody have similar issue?
Thanks for help
Bo
Old May 26, 2009 | 03:41 PM
White08H3's Avatar
Is it squeaks? Maybe from the suspension? Have you been off roading lately?
Old May 27, 2009 | 02:07 AM
Bo's Avatar
Bo
yes I did some off roading. It doesn't squeak, it sounds like there is someting loose, but only when it's cold weather, and allover the car. What about silent block? It's made from rubber, so it can react to the temperature.
Thanks a lot.
Bo
Old May 28, 2009 | 11:19 PM
Heysdad's Avatar
Cool Steering Shaft TSB
I would bet it's you steering shaft. It's a known issue. Take it to the dealer and tell them you have the steering shaft Bang issue that there is a TSB on and you want it fixed.
Old May 29, 2009 | 03:02 PM
psych0's Avatar
Any issues with the steering wheel becoming off centered constantly? Or alignment going out over and over?
Old May 29, 2009 | 04:32 PM
White08H3's Avatar
There is a whole thread on the steering shaft issue. I thought I heard it during the winter, it sounded like something was loose and the dealership just greased stuff up and it went away. They said that if it continued to bring it in and they would look and change out the shaft. It is a known issue and it could be that.
Old May 30, 2009 | 08:59 PM
ukpaul's Avatar
Something like that was happening with ours...
It sounded like an old shopping cart going down the road. Any little bump or turn.
Took it to the dealers and they told me that I had a packet of wheel lug nuts in the trunk and they took them out and the noise dissapeared....I thought "yea right" !
I didn't even get off their parking lot when i heard it again.
Well, on the forum here I read about the body mount thing.
Undo each body mount in turn and squirt silicone lubricant around it and tighten back up.
Whole thing took about 15 to 30 minutes and haven't had a noise since.
Also,I will add, I didn't actually feel it sounded like body mounts but I thought I'd try it anyway. It proved me wrong......
Old Jun 4, 2009 | 02:01 AM
Bo's Avatar
Bo
I talked to the dealer yesterday and it was a pain in the a....I had my off road tires on it (toyo M/T 315/75/16) and when we went for a ride with the service guy to hear the noise, he started to complaine about those tires that they are the problem and if I will put back on my original tires, the sound will disappear. So I told him that the same problem is with my original tires and he said that if I will not put those tires back he will not work on the car. He also said that this is the off road car and sooner or later I will hear noises coming all over the car. I told him that's too bad if car for $40.000 with 30.000miles on it will sound like old car for $3000. So anyway he let me change the tires and recomended me that I should better clean the car underneath otherways if he will find the dust sitting somewhere I will be responsible for the bills. So I changed the tires and washed the car underneath and today morning I went back. The same noises allover the car. I tried to tell him if he can check the steering shaft and he said it's not this case. Than I said if he can check the bushings and he said that they are fine and that they are not going to change them... So he will work on the car tommorow so we will see. By the way when I was sitting with the representative in the office he started to tell me that I'm the only one in bay area with this issue and that maybe it's our fault that we are too sensitive to the noises (he wasn't with us when we went for test drive) so I don't know. In my opinion they are trying to extend the fixing time because my warranty is going to expire in 10 days.
So now I just must hope that thay will fixit til my waranty will expire.
Ps: I was there last week with the same isue thay lube everithing but it didnt fix anything.
I will keep you inform how it continus
Old Jun 4, 2009 | 03:28 AM
twinmill28's Avatar
Default Jerry Seiner HUMMER Salt Lake City rocks!!
Holy crap, sounds like you have Ford service people working at your HUMMER dealership--you are dealing w/ HUMMER--right? My wife and I will never buy another Ford again because of this kind of disrespectful service; we have been given the run-around and "normal operating condition" line from multiple Ford service depts before we finally sold that lemon after it went out of warranty and blew its motor at 85K miles. We currently take our H3 to Jerry Seiner HUMMER in Salt Lake City and cannot say enough good things about their customer service. The tech who takes our truck won't even let me finish a sentence before he is prepping the H3 to go into the service bay to address any issue we bring up. They have a burger joint in the middle of the dealership and give us coupons for free drinks while they look it over and we grab a bite to eat. It's unfortunate that the HUMMER dealers are so far spread out like they are that you can't get to another dealer for the service that you deserve. We actually have two HUMMER dealerships/service depts in Salt Lake, but have never had the need to go to the other one. Hopefully under it's new ownership, HUMMER can get a larger dealer network going and provide EVERYONE the level of service that we know them for--I don't even think the Cadillac guys get treated as well as we do! Good luck with your troubles, but I'd make sure that your concerns are well documented in your visits to the dealership so that even when your H3 goes out of warranty you can push them in honoring a known problem even after the warranty expires because it was ID'd prior to the warranty expiring.
HummerGuy
Jan 13, 2008 10:33 PM
j e f f x o 6 x
Jun 29, 2007 06:21 PM
WOLFGANGSTA
Feb 11, 2007 03:55 PM
crc2k
Sep 1, 2006 04:03 PM
skeeet
Mar 16, 2006 05:21 AM
