PCM question
Old Sep 4, 2014 | 08:39 PM
byeatts's Avatar
Default PCM question
Hypertech said the adjustable modual fits 07 and newer because the 06 ecm dosnt have the options built in for shift points, my 06 has a Manual transmission and the shift point are not an issue, Will it work to trim the fuel curve/timing, PCM for less was lean with my headers and cat forward and cat back system, the jet chip is fairly close however a tad lean under excelleration. I recall seeing a device that wired into the MAF sensor fooling the system and could turn a dial to richen the fuel curve?
Old Sep 4, 2014 | 09:50 PM
byeatts's Avatar
heres what I found, My Jet chip already adjust most all the parameters however just a tad lean with all my mods, I have ordered an adjustable modual that alters the O2 sensor reading and can dial in a tad more fuel on the fly, It says its works along with other chips, will see how this works , not expensive at all to try,
Old Sep 10, 2014 | 02:48 PM
Bigwilliedw's Avatar
byeatts - what did you order that alters the O2 sensor readings? Can you post a link? Thanks.
Old Sep 10, 2014 | 05:04 PM
byeatts's Avatar
the adjustable modual ties into the MAF air sensor wires and fools the PCM . by changing the output signal it can tell the PCM that the air temp is colder than the actual temp, Thus adding a tad more fuel/richer mixture. I installed under the dash and can be adjusted while driving. I will look for the link.Yes you can do this with a resistor however it is fixed and not adjustable on the fly.
Old Sep 10, 2014 | 05:05 PM
byeatts's Avatar
www.performancechiptuning.com
Old Sep 11, 2014 | 01:52 PM
Thanks byeatts!
kevin s
Jan 4, 2013 09:20 AM
mattp_160
Dec 9, 2012 04:27 PM
jvorpahl
May 15, 2011 05:05 PM
motley1987
Aug 9, 2008 01:00 AM
motley1987
Jul 18, 2008 04:58 PM
