Over heating
Old Oct 19, 2012 | 08:50 AM
Deputyj's Avatar
Default Over heating
I have an 07 H3. Recently I brought it in for service. The power steering fluid was replaced, it was spilled all over the engine compartment. I waited for the vehicle to cool. And I cleaned out the areas that were covered. I used drag soap and a small amount of water. So that I didn't soak down the engine compartment. Now the problem I'm having is the engine is over heating and I have small amounts of coolant dripping down onto the passenger side floor. Also front passengers window and windshield on that side are fogging up.
Old Oct 19, 2012 | 09:35 AM
You have a bad heater core, that will leak on the passenger side, the exposed hot fluid will fog windows.
That is a separate problem from your overheat. If your radiator has power steering fluid all over it, then it will inhibit heat transfer because the cooling fins are dirty. Might try a good cleaning of that, front and back, with mild soap and a thorough rinse (do not pressure wash).
Nukejob
Jul 12, 2021 11:14 AM
GWhite854
20
Sep 10, 2016 09:32 PM
MeBelovinMyH3
May 9, 2012 10:04 PM
roni
19
Jul 19, 2011 10:27 AM
Allen
Apr 28, 2008 01:10 PM
