Oil warning light on my h3
Old Nov 8, 2015 | 04:35 PM
Luis Rodriguez's Avatar
Default Oil warning light on my h3
My Oil warning light comes on after i drive it for about 30min, only went i get to a red light and goes off on take off. Does any body know why ???
Old Nov 9, 2015 | 06:44 AM
choochmalooch's Avatar
Cool
Welcome to the forum. I would post this down in the H3 section. Give a better description of what you are seeing, what you have checked, and your year and engine size.
Old Nov 9, 2015 | 10:19 AM
Moved for you. First thing to do is verify the oil level. Is it full?
Old Nov 9, 2015 | 08:42 PM
Thanks for moving my post to the right place..... I have a '06 H3 with 250,000 miles and recently have been getting the red low oil pressure lamp when come to a stop at idle. If I give it just slightly enough gas to bring the rpms from the 600-700 up to 900-1000 it will turn right off. On a cold start it doesnt seem to do it but i also noticed that the idle is a bit hight on a cold start and then in slowly drops to 600-700 rpms.........
Old Nov 9, 2015 | 09:39 PM
happythree's Avatar
cold oil=higher pressure. 250000! warm oil and worn bearings, oil pressure drops at low rpm,jumps up at high rpm. all my old hi mileage cars did that.
my guess is a worn motor, 250000huh???
i had a van at 143000 coasted to a stop when oil pressure went so low it wouldnt pump up the lifters, one rod bearing was the worst.
i put in a long block.
you can try 10w30 or 20w40,,,for a while. i ran 20w50!!but in winter it wouldnt drain down to the pan till it got warm, finally died at 143000.
Old Nov 10, 2015 | 07:22 PM
Got it !! Thank you . I think i will start looking for a engine. The h3 is super clean so is worth putting a new one and keeping. Thanks again
Old Nov 11, 2015 | 06:27 AM
Have a local mechanic do a cylinder leak down test.
Old Nov 12, 2015 | 03:47 PM
Gomer's Avatar
lol um before looking for a new engine make sure of the oil level. My light came on once and I was like a quart or two down. Topped it off back to normal level and all has been well. Never did figure out why it was so low and have not had any problems or water in oil etc.. just a gremlin getting thirsty I guess. Anyway check the oil level first.
Old Nov 19, 2015 | 03:24 PM
ODIMUS's Avatar
Check your oil pressure sensor. Under 50 bucks and takes 15 minutes to swap out. Had the same problem.
Old Nov 19, 2015 | 07:53 PM
happythree's Avatar
years ago i could buy a brass"t" that would allow use of the regular sending unit and a mechanical guage on ford engines.
i cannot identify the threads used on the h3 oil sender, seems like an odd size,not sae or metric.
id like a real guage like the good old stewart warner 2 inch with copper tubing!
thread type???
