oil pressure gauge pegged?
Old Sep 18, 2013 | 04:30 PM
rodtx's Avatar
Question oil pressure gauge pegged?
I have done searches and the consensus is the oil pressure sending unit or gauge cluster problem when you turn the key the gauge pegs before you start it should I assume its the gauge or go with the sending unit also I have no other dash lights or information center warnings for it and it stays pegged and doesnt move. Thanks for any help.
Old Sep 18, 2013 | 04:44 PM
H2CANEPADESIGN's Avatar
Well, it would be a hell of a lot easier to replace the sending unit first.
Old Sep 19, 2013 | 06:03 PM
LoJac963's Avatar
If that's the only gauge that is acting funny it may be the stepper motor for that gauge. As mentioned you could either start with the oil pressure sending unit or the gauge.
If you've messed with your gauges then you know the disassembly procedure and yadda yadda. I've had mine apart a number of times.
Which route you take it totally up to you. I believe if you have a multimeter you can test the sending unit without removing it.
Old Sep 19, 2013 | 07:23 PM
happythree's Avatar
I would unplug the sender,see what happens. you'll learn a lot
Old Sep 23, 2013 | 05:21 PM
rodtx's Avatar
It was the sending unit. Thanks
Ghost Rider
20
Jan 20, 2016 10:22 AM
JMGPhila
May 2, 2015 12:20 PM
myrddin
Dec 16, 2012 11:54 PM
hoffman
Nov 29, 2011 08:49 AM
rreynolds2816
Jan 27, 2009 03:44 PM
