door spring stops/hinges
Old Sep 22, 2013 | 06:37 PM
andy camp's Avatar
Default door spring stops/hinges
New here, just bought an 07 and realized previous owner perhaps had removed front doors and did not reattach the spring stops and bolt hinges back, any clues as to how to pull spring stop out all the way and what size bolts do I need.
thanks for any help
Old Sep 22, 2013 | 08:28 PM
happythree's Avatar
get some metric6,8, try till u find. I think its 6mm?? its very hard to pull it out while the door is mounted,so,,,
then its not ez I put bolt part way in,tied strong wire to "closer" and wrapped around the bolt when door was as far closed as I could get it,open door. hold door open,unwrap wire off bolt,close it as you can, and rewrap as short as you can. it will be hard to hold.
repeat a few times till "finally" the closer clicks out. you can then,carefully put the bolt thru the closer bar and get it started. if you bump the bar b4 the bolt gets started,well then you get to do it all again!!. then you become the xpert. right now I am!!
oh, are the small unpainted bolts in the hinges,one in each?. if not the door could bounce off on a hard bump! it just sits on the hinge pins and those bolts hold it in place.
Old Sep 22, 2013 | 08:36 PM
andy camp's Avatar
Thanks, sounds like a lot of fun. I will give it a shot. Thanks again for the advise.
Old Sep 22, 2013 | 08:43 PM
happythree's Avatar
oh yeah,its fun!!. reread that since I was editing when you last posted.
I used some tough stranded wire, like guy wire.
Old Sep 23, 2013 | 03:01 PM
andy camp's Avatar
Hey Happy, great news, got them....However, I tried you method and couldn't get it to work for me, came up with a new one - simple method. Get a long screwdriver 12-14 inches and pass it through spring end then carefully put it in threaded hole and open door! worked perfectly. thank you for making me think about it more than I had been.
Old Sep 23, 2013 | 05:25 PM
happythree's Avatar
great!, sounds too ez,id love to try it but NO im not unhooking it!!
so nyou are the xpert now!
madmayo
May 7, 2015 12:37 PM
design8studios
Nov 19, 2011 03:05 AM
Neptune262
Dec 14, 2010 03:12 PM
veves
Jul 6, 2008 06:32 PM
littlehummerboy
21
Apr 2, 2007 01:03 AM
