Oil Change Question
Old Jul 27, 2012 | 07:01 PM
DaWgPoUnD's Avatar
Default Oil Change Question
2008 H3X
Changed the oil/filter today in my H3 and drained a little more than 5 qts out (truck on ramps so maybe left some old in back side of pan?) Anyway, put 6 qts in of which added the last 3/4 of a qt after checking stick and looked about 1 qt low. After letting is sit for a while checked stick again and it looks to be about 1/4 qt over fill (above the full mark). Is there an "over fill" limit or such that if you over fill to a limit that will put to much pressure on seals? I am curious before I over react and pull the plug and drain some of it back out?
Thoughts?
Thanks in advance
Old Jul 27, 2012 | 07:28 PM
2wheelmonster's Avatar
well I've never had an issue with it being over full that much. I would say a full quart might be pushing it. worst case scenario, drive it down the highway full throttle for an hour straight and that should burn off 1/4
Old Jul 27, 2012 | 09:17 PM
carloscrx101's Avatar
Fill to what Is recomended over fill is not good for oil control pistons rings to much oil makes the rings to not work properly after so many times that u over fill u motor they create some hard oil gunk on the rings and motor will smoke blue (exhaust) it takes more that one over fill for this to happen but if it is my car I just get the oil out to the right amount..good luck
Old Jul 28, 2012 | 10:41 AM
Xlr8n's Avatar
Drain completely. Tilt the vehicle with a jack if needed to get all the old oil out. Add six quarts with a new filter and run it for a bit. Observe where the new oil level is on the dipstick. Scratch a permanent line at that point. That is now your accurate 'full' line. I trust knowing the engine requires 6 quarts before I trust the premade lines on a manufactured dipstick.
Old Jul 28, 2012 | 10:47 AM
happythree's Avatar
I drain on the level,no need for ramps, i never measured how much came out, new filter and 6 qts, it reads a little high.
I dont sweat it, they call for 6 and thats what i use.
I DEFINETLY WOULD NOT DRIVE AT FULL THROTTLE,, ANYWHERE, ANYTIME. ITS NOT A FIX!!
Old Jul 28, 2012 | 11:17 AM
Agree on last post 100%
Old Jul 28, 2012 | 03:42 PM
bosoxdew's Avatar
I completly agree with happythree.....DO NOT DRIVE FULL THROTTLE.
Old Jul 28, 2012 | 03:51 PM
DaWgPoUnD's Avatar
Drained and refilled on level. All is good now. Thanks for the responses.
Old Jul 29, 2012 | 11:17 AM
bosoxdew's Avatar
Glad to hear it worked out for you
rhill20
Jul 1, 2013 12:23 PM
drtom
Jan 17, 2011 09:23 PM
hummer07
Nov 18, 2008 10:46 AM
hummer1
16
Jul 7, 2007 07:16 AM
CDiPrecision
May 27, 2007 01:22 PM
