OEM FACTORY LIGHT SWITCH
Old Jul 23, 2007 | 07:30 PM
dilo2001gt's Avatar
Default OEM FACTORY LIGHT SWITCH
Has anyone bought oem factory light switch for the H3 for lights .
They go where the two plugs are below the radio ?
Old Jul 24, 2007 | 12:25 AM
Gunner_45's Avatar
Default RE: OEM FACTORY LIGHT SWITCH
You talking about these guys: Hummer H3 Off Road Lamps Switch 88963884 Connector 12101864
"The switches for the off-road lamps are located in the center of the instrument panel below climate controls.
One switch is used for the front lower-grille mounted off-road lamps, if equipped, and the other switch is used
for the roof-mounted off-road lamps, if equipped."
The switch is actually 2 pieces. The switch and a connector (pigtail harness).
The switch comes with no documentation, but if you look close on the back of the switch you will see
the markings A, B, and C for the respective pins.
A: GND
B: Accessory
C:+ 12v
Note: I see A and C swapped in quite a few posts across several forums.......Installer beware.....
Old Jul 24, 2007 | 07:03 AM
dilo2001gt's Avatar
Thanks GunnerI love this forum I bought two switches but i was woundering about the connectors. I have to order those.
Thanks again
Mark
SundownAudioNY
Sep 6, 2011 03:02 PM
reed75
Jul 3, 2010 09:46 AM
FloridaFeMan
20
Feb 18, 2010 08:19 AM
gregaac
Jan 10, 2009 10:00 PM
gprotein
Dec 24, 2007 12:46 PM
