obd code p04?
Old Apr 10, 2015 | 08:36 AM
mephis2012's Avatar
Default obd code p04?
hi ive got a 07 h3 5cyl. the engine light has come on and I scanned it with obd2 and my smart phone and it came up with p04? I cant seem to find any info on that code.any ideas would be greatfull.thanks
Old Apr 10, 2015 | 09:19 AM
ProphetPVD's Avatar
You're missing a couple of digits... Unless I am mistaken, GM OBD2 codes are always in a P0XXX format, and P04 would be emissions related. The last two digits would indicate what component of the emissions system is at fault.
Old Apr 10, 2015 | 09:46 AM
mephis2012's Avatar
ive cleared it but if it comes back ill scan it and take a screen shot and add it here.im sure it said p04 but could be mistaken.thanks
Old Apr 10, 2015 | 10:06 AM
What ProphetPVD said.....
FAQ: OBD2 Codes Explained
OBD-II codes consist of a number of parts. Here is a sample OBD2 code: P0171
Here is a breakdown of what each digit of the code means:
First Character - System The first character identifies identifies the system related to the trouble code.
P = Powertrain
B = Body
C = Chassis
U = Undefined Second Digit - Code Type
The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code. 0 = Generic (this is the digit zero -- not the letter "O") 1 = Enhanced (manufacturer specific)
Third Digit - Sub-System The third digit denotes the type of sub-system that pertains to the code
1 = Emission Management (Fuel or Air)
2 = Injector Circuit (Fuel or Air)
3 = Ignition or Misfire
4 = Emission Control
5 = Vehicle Speed & Idle Control
6 = Computer & Output Circuit
7 = Transmission
8 = Transmission
9 = SAE Reserved
0 = SAE Reserved
Fourth and Fifth Digits These digits, along with the others, are variable, and relate to a particular problem. For example,a P0171 code means P0171 - System Too Lean (Bank 1).
Read more at: OBD-II Codes Defined
Old May 4, 2015 | 10:21 PM
mephis2012's Avatar
thanks guys it was the petrol cap causing the engine light to be on.some1 tried steal it :-(
Alex2012
Oct 1, 2012 01:53 PM
madmike
Jan 9, 2012 09:14 PM
Ken06H3
Dec 1, 2011 09:46 PM
yellow7
Oct 4, 2008 11:16 PM
HummerGuy
Feb 20, 2007 12:43 AM
