obd code p04?
hi ive got a 07 h3 5cyl. the engine light has come on and I scanned it with obd2 and my smart phone and it came up with p04? I cant seem to find any info on that code.any ideas would be greatfull.thanks
You're missing a couple of digits... Unless I am mistaken, GM OBD2 codes are always in a P0XXX format, and P04 would be emissions related. The last two digits would indicate what component of the emissions system is at fault.
What ProphetPVD said.....
FAQ: OBD2 Codes Explained
OBD-II codes consist of a number of parts. Here is a sample OBD2 code: P0171
Here is a breakdown of what each digit of the code means:
First Character - System The first character identifies identifies the system related to the trouble code.
P = Powertrain
B = Body
C = Chassis
U = Undefined Second Digit - Code Type
The second digit identifies whether the code is a generic code (same on all OBD-II equpped vehicles), or a manufacturer specific code. 0 = Generic (this is the digit zero -- not the letter "O") 1 = Enhanced (manufacturer specific)
Third Digit - Sub-System The third digit denotes the type of sub-system that pertains to the code
1 = Emission Management (Fuel or Air)
2 = Injector Circuit (Fuel or Air)
3 = Ignition or Misfire
4 = Emission Control
5 = Vehicle Speed & Idle Control
6 = Computer & Output Circuit
7 = Transmission
8 = Transmission
9 = SAE Reserved
0 = SAE Reserved
Fourth and Fifth Digits These digits, along with the others, are variable, and relate to a particular problem. For example,a P0171 code means P0171 - System Too Lean (Bank 1).
Read more at: OBD-II Codes Defined
P = Powertrain
B = Body
C = Chassis
7 = Transmission
8 = Transmission
9 = SAE Reserved
0 = SAE Reserved
Alex2012
Oct 1, 2012 01:53 PM
yellow7
Oct 4, 2008 11:16 PM
HummerGuy
Feb 20, 2007 12:43 AM
