no heat
Old Dec 20, 2011 | 02:54 PM
angelabell71's Avatar
Default no heat
no heat/ac the lights dont come on,on the control panel it doesnt blow,heat/ac fuse is fine.but i can feel just a little heat coming out of vents when i get on the expressway.
Old Dec 20, 2011 | 07:44 PM
wvu maniac's Avatar
If the lights are out on the control panel it most likely needs to have the module(control panel) with the *****. You feel little heat from vents because while your moving the natural air flow is coming through. If you try different fan speeds and no different? then I think you really have two problems. Lights out on panel need to replace that. Look under your glove box and you will see a red connector for the blower motor resister. Disconnect it and you will find the larger of the wires burnt. The dealer sells the connector,harness for the relay and resistor and fan,resister. The numbers have been super seeded but the parts guy can locate. I have had both problems happen on my 06 H3 and repaired myself. If you find it burnt I can get you part numbers from the spares I have.
Old Dec 26, 2011 | 07:52 AM
Default thanks
i disconnected the plug under the dash and the wire wasn't burnt, reconnected it and guess what everything started working i dont know if it has a short or my kids kicked it but thank you so much
khalidcito
Apr 18, 2009 06:17 AM
JeepeaterH3
Jul 8, 2008 11:04 PM
Koboss
Jan 29, 2008 03:56 PM
drbombay
Sep 3, 2007 07:07 AM
jwiz1971
Jul 17, 2007 09:13 AM
