New Shocks?
Old Dec 19, 2007 | 03:26 PM
mattroberts123's Avatar
Default New Shocks?
Ok... well I just put my stock wheels and tires back on my SUT... and it is riding ROUGH! Bouncing all over the place and not handling the road well at all.
I remember when I first got the truck a little over a year ago, and it rode like a dream!!!
Could my shocks be going out this quick? I fear that if I take it to a shop and ask that question, that I instantly will be buying myself a new set of shocks...
Any suggestions?
Old Dec 19, 2007 | 08:56 PM
Camou2's Avatar
Default RE: New Shocks?
Matt, if it wasn't bouncing and all over the road before you reinstalled the original rims and tires then it probably isn't your shocks. It is probably you tires.... go have them checked out and balanced....
Old Dec 20, 2007 | 08:15 AM
What is the PSI of the stock set -vs- the aftermarkets you just pulled off? And is there a sidewall profile difference between the two sets?
Old Dec 21, 2007 | 09:54 AM
Matt,
If you stored the stock tires standing up instead of horizontally you may have created a flat spot in the tires. It may or may not drive out after awhile. It also could be that you need to have them rebalanced. I would drive the truck as much as you can for 4-5 days and see if it corrects itself. I have 5 vehicles and some are worse than others about sitting. I have an H1 with GSAs on it and if it sits more than 4-5 days I go through a short period of "rounding" out the tires again. I also have one with MTRs and it doesn't seem to suffer than problem nearly as quickly.
Old Dec 21, 2007 | 01:39 PM
TheGunnyRet's Avatar
Shocks don't go bad from changing rims,it road fine with the aftermarkets correct?check your psi and see if any weights fell off.
Perantes
Dec 5, 2011 02:40 AM
jaymazurk
16
Sep 15, 2011 12:53 AM
psych0
Apr 20, 2010 11:08 PM
psych0
Mar 11, 2010 07:22 PM
samkelly
Dec 11, 2008 12:23 PM
