New to me 2007 H2 - What to repair first?
your bump stops look to be in bad condition or non existent . your shocks need replacing (if you look at the top end at the rubber bush they are wet) and your exhaust manifolds are missing shields which usually coincide with you might have cracks or missing exhaust bolts. ask me how i know lol. also check your stabilizer bushings and link bushings
Adding to that already said, some of your zerks need grease.
GM considers shock wetting like this normal. Ask me how I know….
Just do a bounce test. I bet they may be ok.
There is a split plastic boot on one shock. Not critical for function.
It keeps splatter and dirt off the piston rods for longer life
If it was me, I would change them. But I am a perfectionist.
Tire rub on front sway bar is normal. OEM tire do not clear it on full lock.
Thanks again for all the help. Got the truck back from the shop and they:
Now she's ready to ride!!!
- Dropped the fuel tank and replaced rusted fuel pump
- Replaced one rusted rear brake line
- Replaced emergency brake cable
- New rear calipers / pads / rotors
- New window washer pump
- New oil cooler lines
- New transmission cooler lines
- Both serpentine belts replaced
