Need new brakes any recommendations?????????
Old Mar 21, 2014 | 09:26 PM
johnocch's Avatar
Default Need new brakes any recommendations?????????
Or should I just go with dura last ?
Old Mar 21, 2014 | 10:09 PM
larry0071's Avatar
Don't use that Autozone garbage. Go to Nappa or get Hawk pads online. Just about everything you can buy from Autozone is trash compared to factory.
Old Mar 22, 2014 | 05:55 AM
Bunger's Avatar
My original pads lasted for over 65K miles so for replacements I went with Delco OEM's.
Old Mar 22, 2014 | 07:04 AM
happythree's Avatar
Default wow
boy do i feel dumb, all theses years ive been using junk in my hot rods.
ill never go back there.
good thing we have old time experts here
i wonder if anyone ever put one type on the left,another on the right?
i do like bungers approach.
Old Mar 22, 2014 | 07:49 AM
larry0071's Avatar
I can only speak from past experience.
I track my car, the brakes they have suck compared to the factory pads from my Camaro, and are not in the same Galaxy as the Hawk. The best Duratrash pads will get you dead on the track.
My father and I sled pull a 4x4 truck. An Autozone U joint will literally snap after the chain is pulled tight and you start to add power.
The front suspension parts my son bought for his 2004 Blazer were mind boggling. I installed upper and lower *****, outer tie rods and idler arm. The following year it failed inspection because it needed front parts, he had put 10K miles on it. I told my son I would go talk to the shop inspecting it and explain that is all new. I went. They put it on the lift and sure as **** the lower ***** were loose and the idler was loose. I was baffled. I went to Nappa to get replacement parts. Screw them and the lifetime warranty on trash at Autozone.
I'll buy oil or spray chemicals there. Nothing that actually goes on my car comes from them.
Old Mar 22, 2014 | 09:51 AM
X2 on the OEM pads for replacement.
Old Mar 23, 2014 | 01:25 PM
NJTEX's Avatar
Centric rotors and ceramic pads perform the same as the factory parts. Their rotors have a high quality finish and their pad kits include all new shims. I now use them on all my GM vehicles.
Old Mar 23, 2014 | 02:02 PM
ACDELCO PRO Ceramic W/hardware (lifetime warranty)
17D1119CH
17D1120CH
$66.26 Front & Rear Shipped from Amazon.
Amazon.com: ACDelco 17D1119CH Disc Brake Pad: Automotive Amazon.com: ACDelco 17D1119CH Disc Brake Pad: Automotive
Amazon.com: ACDelco 17D1120CH Disc Brake Pad: Automotive Amazon.com: ACDelco 17D1120CH Disc Brake Pad: Automotive
ACDelco brakes are independantly tested and D3EA certified to meet the industry's highest level of braking performance
ACDelco Professional DuraStop Brake components are designed to help resist corrosion and premature wear
Include noise-dampening shims where applicable for quiet performance
Limited Lifetime Warranty
ACDelco is an Original Equipment (OE) supplier and has the experience engineering and manufacturing components that achieve the highest quality standards required by vehicle manufacturers
Old Mar 23, 2014 | 02:20 PM
Prime Choice has a Nice price for all 4 wheels($199.48 shipped), with ceramic pads, hardware, & rotors:
Front Rear Kit 4 Performance Drilled Slotted Brake Rotors and 8 Ceramic Pads | eBay
Old Mar 23, 2014 | 10:50 PM
H3ummer's Avatar
Wonder what brand the pads and rotors are in that kit ^^. Anybody have any experice with the slotted rotors on their h3? How do you like them?
