Need info about 3 inch front key and 3 inch rear spacer level lift
Old Jan 5, 2015 | 03:31 PM
jsbihn's Avatar
Default Need info about 3 inch front key and 3 inch rear spacer level lift
Hey all,
I am buying a torsion key and rear spring spacer level lift kit.
I have been told by the manufacturer that to install this I will need taller/longer rear shocks. I am curious if this is true, or for right now can the shocks I have now work? And if/when I get the rear shocks that are longer length, which ones should I get or where should I get them?
I have heard that you do need them, and you dont but they will be extended to the max.....? So of course I am curious.... If I can get away with the springs I have now working that would be great
I currently have a 2003 with air ride, which is going to have the spring conversion swapped when I do the lift.
Any comments would be appreciated
Old Jan 6, 2015 | 11:02 AM
accely's Avatar
save yourself the hassle and get the new shocks now IMO.
Old Jan 6, 2015 | 12:06 PM
alamry's Avatar
i am using the ProRYDE DUCK HEAD TORSION KEY FRONT LIFT/LEVELING KIT and Bilstein 5100 Series shocks and Traxda rear coil spacers. i found this to be the perfect cost-effective 3 inch lift with no ill effect on my 05/H2
Old Jan 6, 2015 | 03:36 PM
jsbihn's Avatar
How do i know what shocks will be longer than stock (if I dont want to go with the bilstein)
Old Jan 6, 2015 | 10:48 PM
alamry's Avatar
in general you should aim for long travel shocks that will work with the 3 inch lift
28sNoRubs
Feb 24, 2015 09:36 AM
roycel
Jan 9, 2011 12:58 PM
2wheelmonster
Nov 15, 2009 06:16 PM
Flyboy23
May 14, 2009 12:13 AM
Nxsov180db
May 1, 2008 09:38 PM
