Need help quick! My wheel is wobbling on H2
Old Jul 5, 2008 | 02:34 PM
cisco's Avatar
Default Need help quick! My wheel is wobbling on H2
I have posted a couple times about noises I am hearing in my front end. I went out and looked underneath and saw that the disc brake guard underneath the rotor on the driver front wheel was slightly rubbing on the disc. I figured, ah ha, found the culprit. I get a screwdriver and start to pry the gaurd out a little and the entire wheel, hub and rotor moves! I went to rock the wheel and I can move the entire thing. I jack up the car and I can wobble the entire wheel/rotor/hub with no problem. I tried the same thing on the other side and it is tight as a drum. What is going on? Please help
Old Jul 5, 2008 | 04:56 PM
DILLIGAF08H3's Avatar
Default RE: Need help quick! My wheel is wobbling on H2
are the lugnuts tight?
Old Jul 5, 2008 | 04:58 PM
Intercooled's Avatar
I'm no mechanic, but maybe a wheel bearing?
Old Jul 5, 2008 | 05:36 PM
ronb's Avatar
have it towed to the dealer.
Old Jul 5, 2008 | 07:29 PM
Definitely
Old Jul 5, 2008 | 09:43 PM
ASAP........[:@]
Old Jul 7, 2008 | 09:52 AM
cisco's Avatar
bearing, and possibly some other stuff shot apparently. Getting fixed today. What's scary is I am not asure how long it has been like this and I have been back and forth from LA to AZ a couple times in just the last week and a half.
Can you just replace just the bearings or do you need to replace the entire hub unit? I see parts for bearings and for the hub itself on gmdirect but not sure what I need. I ahev someon I trust that is going to look at it today and fix it, but would like to have an idea going in.
hrlyguy2
May 31, 2013 05:46 PM
LoJac963
Sep 13, 2011 12:12 PM
beachbum
Sep 10, 2010 12:50 AM
agsadent
Jul 1, 2008 11:16 PM
bdisanto
39
Feb 22, 2008 12:40 PM
