need help with brakes on h1
Old Feb 21, 2011 | 10:53 AM
SEXTON's Avatar
Default need help with brakes on h1
i bought a 2001 h1 the front brake pads are fine but rattle in the caliper. im guessing whoever changed them didnt re install the retainer clips. does anyone have a diagram of how to install the clips.
Old Feb 21, 2011 | 11:43 AM
I do but they are in my manuals at home. It will be tomorrow before I can post them up. Might PM Hummech and see if he can get them to you sooner.
Old Feb 21, 2011 | 12:32 PM
SEXTON's Avatar
Default 3hummers
im not in any hurry, i had to order the clips and they wont be here untill tomorrow. if you have time, can you email me a diagram PLEASE.
Old Mar 22, 2011 | 11:04 PM
Forsche's Avatar
I changed my 2001 brake pads front and back and there were no clips in. You do have to chamfer the pads, there is some great info on flashoffroad for this.
Old Mar 24, 2011 | 12:10 AM
HummerWrench's Avatar
Smile brake rattle
Hummer H1 do not have any brake anti rattle clips. DO NOT have them.
The biggest problem with a rattle is the caliper brackets are worn from the brake pads over the years. Also you might have Diff bearings that are loose. If you can check take the rotor and move it side to sid then you need bearings and i recommend stub shafts.
Top check the caliper brackets you can remove brake pads and check for low spot where the pads rub.
Please let me know if you need any help
hummerwrench@gmail.com
GBergie
Aug 26, 2015 04:57 PM
johnocch
43
Dec 30, 2014 10:30 AM
MeBelovinMyH3
Nov 3, 2012 08:58 AM
Herm
Nov 24, 2009 02:39 AM
sbsisco
Jun 23, 2008 02:17 AM
