need help in adjusting coil spring
Old Apr 13, 2014 | 07:10 PM
masterpogi's Avatar
Default need help in adjusting coil spring
My air bag was worn out so i decided to replaced it with coil spring. The mechanic adjusted the torsion bars because the rear is obviously high from the front. After they adjusted i measure the height from tire to fender.....left and right front is 7.5 inches rear left is 9.2 inches and rear right is 8.5 (also found out that the left and right rear is not the same ). Wondering what should i do to adjust the rear coil springs at rear end.....thanks in advance..
AndyMac
Feb 3, 2024 10:44 AM
sagev
Jan 17, 2013 11:41 AM
itsxthexslim
Apr 7, 2012 11:04 AM
Nxsov180db
May 1, 2008 09:38 PM
AZ Hummer
Mar 22, 2008 07:12 PM
