Air suspension coil spring conversion thread.
Old Jan 23, 2011 | 06:08 PM
AndyMac's Avatar
Default Air suspension coil spring conversion thread.
I've been searching a few different sites, but haven't found any real threads on converting the rear air suspension to coil springs.
There are "kits" out there starting at 299 and up. It took a little digging, but all these kits contain are 2 coil springs, 4 isolators and instructions. You just need the OEM GM parts to do the conversion.
1 coil spring - GM part# 25956182 (left??) #7 in diagram
1 coil spring - GM part# 25956183 (righ??) #7 in diagram
4 coil insulators - GM part# 15713853 #8 in diagram
If you buy from GMpartsdirect.com, the total cost is 233.57 shipped.
So, if someone could confirm the part numbers and maybe confirm which relay needs to be removed so that the "service air suspension" warning doesn't show up in the DIC when the compressor is removed, that would be great. Obviously any other info would be appreciated too.
Thanks,
Old Jan 23, 2011 | 07:17 PM
Easy Ed's Avatar
Couple post on another forum that may help some. Your part numbers look correct and if they are not marked left or right, in one of the links below it is discussed how to tell left from right on the springs.
Good luck, Ed
http://www.elcovaforums.com/forums/s...ad.php?t=40631
http://www.elcovaforums.com/forums/s...ad.php?t=38543
http://www.elcovaforums.com/forums/s...ad.php?t=24471
Old Jan 24, 2011 | 04:12 AM
AndyMac's Avatar
Thanks for the Links Ed!
Old Jan 24, 2011 | 02:32 PM
Easy Ed's Avatar
No problem, best of luck changing them out.
Ed
Old Feb 4, 2011 | 08:59 AM
AndyMac's Avatar
So, about 10 days ago, my air suspension took a dump and I had to ride around on the bump stops to/from work.. (very uncomfortable) Since I'm in Canada, it's difficult to order from gmpartsdirect.com and I needed the parts fast.
I ended up buying a spring conversion "kit" off ebay, that just consisted of 2 springs, and some instructions for 299. I had it in a few days.
Once I had the kit, it only took me about 40 minutes to change the springs out, remove the compressor, remove air suspension relay, reset the computer. The key here was using my spring compressor for the coil springs so I didn't have to drop the shocks and sway bar.
Thanks to Ed, I removed the relay in the drivers fender area and unhooked the battery for a few minutes, and I haven't seen any air suspension codes in a week. Thanks again Ed.
Old Feb 4, 2011 | 03:30 PM
Easy Ed's Avatar
Glad to be of help and thanks for letting us know how it went.
Ed
Old Apr 26, 2012 | 02:46 PM
808Hummers's Avatar
I'm curious to know if anyone here has used the part numbers that Andy listed above to do this conversion.
I need to order a kit today, and I've found one on eBay for $229 plus shipping, but I'd rather order GM parts if possible and if it's confirmed that these part numbers will work.
Thanks.
Jim
Old Apr 26, 2012 | 02:51 PM
crewj's Avatar
Default coil kit
I have a brand new kit that i`m selling in the classified ads with with the rubber insulators for 225.00 shipped. Let me know
Old Mar 19, 2013 | 01:01 PM
Heater's Avatar
hey guys... i just purchased from arnot. should get them this week. Also bought some bilstein shocks. Do you guys find the rear rides alot harder? i have heard it does. and do you tow at all with it? I dont really but have a boat... need to tow the odd time but not much... should be fine?
Old Mar 19, 2013 | 03:50 PM
H2CANEPADESIGN's Avatar
This is an older thread but as for the towing the rear end will lose its leveling capabilities. I doubt that the ride is going to suffer at all. The systems are essentially the same wether your supporting the weight of the vehicle with a spring or a bag full of air. same pricipal.
