Need help
Old Dec 29, 2015 | 02:56 PM
Hsmith's Avatar
Default Need help
Driving home from the holidays, my h3 felt like it went into neutral. I can lock 4 high an 4 low an move but it's just the rear tires. I have not heard any popping or weird noises. Where should I start. Thanks for any help.
Old Dec 30, 2015 | 10:19 AM
Sounds like a T Case problem.
Always include year, model (Base/Adventure/Lux/Lux Off Road) and mileage with a question. Model is important as different T Cases and TCCMs were used.
Old Dec 30, 2015 | 10:45 AM
Hsmith's Avatar
08 adventure just hit 80,000
Old Dec 30, 2015 | 11:51 AM
With the H3 being full time 4wd if anything in the front drivetrain is broken the transfercase will not move the vehicle in 4HI because it tries to send all of the power to the output of the transfercase with the least resistance.
With your vehicle in 4HI lock or 4LOW lock the transfer case will split the power 50/50 to both front and rear outputs regardless of any issue front or rear.
Check both of your front 1/2 shafts, front differential, the front prop shaft (drive shaft) and the transfercase. One or more of these items has to do with your issue.
Old Dec 30, 2015 | 12:28 PM
Hsmith's Avatar
I will check that seems to be the lesser of the two. Thank you.
Old Dec 30, 2015 | 12:30 PM
Hsmith's Avatar
Thank you
importkiller
29
Jan 15, 2008 02:51 AM
WOLFGANGSTA
Feb 11, 2007 03:55 PM
crc2k
Sep 1, 2006 04:03 PM
skeeet
Mar 16, 2006 05:21 AM
efrainl956
May 16, 2005 10:46 PM
