Lower Ball Joint
Old Jan 26, 2009 | 04:46 PM
jstdoitt21's Avatar
Default Lower Ball Joint
I went to get a alignment then the guy comes back to me saying your lowering ball joints need replacing, how would I know if this is true??
Old Jan 26, 2009 | 10:13 PM
Quijy's Avatar
Default RE: Lower Ball Joint
take it somewhere else. Ask them to do the alignment, if there is a problem, they will tell you.
Old Jan 27, 2009 | 11:57 AM
jstdoitt21's Avatar
thanks thats exactly what i was planning on doing!!
Old Jan 27, 2009 | 01:15 PM
HumminNBoatin's Avatar
Simple Jack up the front of the truck. Grab the top and bottom of the wheel and try to rock the wheel off camber. If it moves you got problems. If it does move have someone else rock it while you inspect from the backside to see if the ball joint is moving or if the movement is in the HUB.
Old Jan 27, 2009 | 02:02 PM
jstdoitt21's Avatar
thanks very much for the advice!!
Old Oct 15, 2013 | 03:51 PM
BlackOps2005's Avatar
I took my H2 for my air bag light and I was told about all kind of other maintenance needed to take place. The diagnosted all the problems and issues and after I received the list of parts I went and bought them some place else. I'm doing the work my self. Have you replace a lower ball joint yet? What are the steps if you can advise.
smigelskijk
Oct 25, 2013 02:12 PM
BlackOps2005
Oct 16, 2013 10:23 AM
madmaxmyers
Jan 28, 2013 10:50 AM
Draketh
Mar 10, 2012 08:05 AM
Ridicrick
Aug 21, 2010 08:22 PM
