Loud knocking after using starting fluid
Old Sep 27, 2013 | 11:03 AM
Blake0496's Avatar
Angry Loud knocking after using starting fluid
Hey guys I had a bad glow plug relay and needing to leave in a hurry the other day so i used some starting fluid ( I guess a little too much) and i started it and it revved up really high and made a big boom now it has a really loud knocking sound in the engine. Any suggestions as to what the promblem is?
Old Sep 28, 2013 | 07:06 PM
Blake0496's Avatar
Well I bent the push rod and broke the rocker arm shaft... $26 fix but DO NOT USE STARTING FLUID
Old Sep 29, 2013 | 09:09 AM
greg260's Avatar
diesels are not suppose to rev hi, are you sure it did not rev hi enough to float the valves and maybe one of the valves contacted the piston bending that pushrod.
Old Sep 30, 2013 | 09:39 AM
Blake0496's Avatar
I think itr was preignition casusing the valve to push up right as the rocker wanted to push down so it snapped right where the bolt was becasue of the pressure...
Old Sep 30, 2013 | 09:17 PM
wiretap's Avatar
You should never use starting fluid on a diesel with glow plugs. You get preignition and can do a lot of damage. You may also want to check for head gasket damage as well. I have seen on several diesel truck forums where people have used it and blown the heads right off their motor. You're lucky if that's all you broke.
Old Oct 1, 2013 | 11:20 AM
Blake0496's Avatar
Well after $450 worth of parts ordered i hope to have it fixed by saturday...
Old Oct 1, 2013 | 12:22 PM
greg260's Avatar
what else did you have to buy, you stated a $26 fix in the first post.
Old Oct 4, 2013 | 01:52 PM
Blake0496's Avatar
Well that was the initial cost... Valve cover gaskets were shot, needed new CDR valve, added TD injectors, injector lines and removal tool, push rod, rocker arm shaft, and glow plug controller. I hope to get the last package today. Ill keep you posted and also my door lock switch lock but wont unlock any of the doors.. Any suggestions?
Old Oct 15, 2013 | 10:24 AM
Blake0496's Avatar
So call me an idiot or whatever but I put evrything on and the engine was seized -_- Ripped the head off in 20 mins.. (It gets pretty east after taking everything off the d*mn 5+ times) Found out that my vlave was broke off and my head is shot and the piston has a few dents and highspots in it.. Im replacing the head. (found one on eBay for 275) and hoping that i wont have to replace the piston also. Ill post pics/vids up later. So moral of the story is DO NOT USE STARTING FLUID ON A DIESEL
Old Oct 15, 2013 | 11:42 PM
I usually just splash a little diesel in the plenum.
H3ummer
Aug 21, 2023 09:51 AM
hmer
Mar 10, 2014 08:57 AM
HummerH3Texas
Jan 21, 2013 03:32 PM
glen4cindy
Aug 23, 2012 07:35 AM
Guy
Feb 22, 2007 10:21 AM
