Looking for some tire size help ....
Old May 16, 2017 | 08:17 AM
dkb123's Avatar
Default Looking for some tire size help ....
Hey guys - I've got a stock 07 H2 and thinking about going up to the 37 KO2s from the 315/70/17s. Looks like it adds 2 inches to diameter (roughly rto 36 from 34). Based on what I can see with height and turn clearance it looks like it could handle it.
Anyone tried this out or have insight?
Thanks!
Old May 16, 2017 | 08:49 AM
Synthetickiller's Avatar
The KO2s are not sized properly.
I've mentioned this a lot, but I have the 35x12.5r17s and they sit at 33.5" tall. I've confirmed on a few different forums that the 37" version sits at 35.5". The 315 stocks sit around 34.4".
If you're looking for a real 37", look elsewhere. If you're ok with a 35.5" tire, then get the 37". I cannot recommend the 35" as they are undersized for the H2.
Old May 16, 2017 | 08:57 AM
dkb123's Avatar
Thanks for the reply ...
I'm going to go for the slight bump up to the 37s (35s) and see how they work.
Thanks!
Old May 16, 2017 | 01:38 PM
mcioci's Avatar
I have 37's on my truck with no lift and I get slight rubbing only when I back up and turn wheel to the right. Weird. I may adjust torsion bars eventually.
Old May 17, 2017 | 05:19 AM
Baldfox's Avatar
I'm thinking about getting the same (37s not BFGs) if i get new rims, is there a particular back spacing to look out for which should avoid the rubbing ? Am not a fan of spacers...
Old May 24, 2017 | 05:31 PM
H2CANEPADESIGN's Avatar
Kind of rough. you just have to trial fit them because they rub on some h2s and not on others.
Andreas_Sweden
Mar 19, 2025 12:16 PM
Treviso
Feb 11, 2016 08:31 PM
Sgill
19
Apr 25, 2013 05:38 AM
Hummer79
Jan 7, 2013 11:28 PM
IN2deep
Oct 15, 2007 09:23 PM
