Looking for some tire size help ....
Hey guys - I've got a stock 07 H2 and thinking about going up to the 37 KO2s from the 315/70/17s. Looks like it adds 2 inches to diameter (roughly rto 36 from 34). Based on what I can see with height and turn clearance it looks like it could handle it.
Anyone tried this out or have insight? Thanks! |
The KO2s are not sized properly.
I've mentioned this a lot, but I have the 35x12.5r17s and they sit at 33.5" tall. I've confirmed on a few different forums that the 37" version sits at 35.5". The 315 stocks sit around 34.4". If you're looking for a real 37", look elsewhere. If you're ok with a 35.5" tire, then get the 37". I cannot recommend the 35" as they are undersized for the H2. |
Thanks for the reply ...
I'm going to go for the slight bump up to the 37s (35s) and see how they work. Thanks! |
I have 37's on my truck with no lift and I get slight rubbing only when I back up and turn wheel to the right. Weird. I may adjust torsion bars eventually.
I'm thinking about getting the same (37s not BFGs) if i get new rims, is there a particular back spacing to look out for which should avoid the rubbing ? Am not a fan of spacers...
Originally Posted by Baldfox
(Post 344607)
