Leveling kit vs torsion bar crank
Old Mar 16, 2008 | 09:18 PM
  #21
rhill20's Avatar
Default RE: Leveling kit vs torsion bar crank
Shocks are cheaper than the kit, like I said though, I still have the stock shocks and no ride problems.
*I told you nobody would agree and you would get a bunch of different opinions*
Old Mar 16, 2008 | 09:38 PM
  #22
alrock's Avatar
Old Mar 16, 2008 | 09:53 PM
  #23
blackbear's Avatar
ORIGINAL: rhill20
Old Mar 16, 2008 | 11:22 PM
  #24
alphadogg's Avatar
ORIGINAL: rhill20
You are going to get all kinds of different opinions here in the next few hours watch.
ORIGINAL: blackbear
I did the torsion bar crank and ran it for 5 to 6 months, then decided to install the leveling kit and that's been over a year now, there is a noticeable difference in the ride, with the TB crank the ride was more stiff,
ORIGINAL: importkiller
turning the t-bars DOES NOT stiffen the ride....it does the same thing a leveling key does except the key gives you added room for even more adjustment. The stiff ride as mentioned by Rhill is that you overextended your stock shocks thus creating a harsh ride...by getting longer shocks your ride will return to normal.
ORIGINAL: josh1899
I leveled mine using stock keys and replaced shocks with Cognito's. I had absolutely no side effects to this mod. Ride is exactly the same. Handles the same. This question is like asking the meaning of life! no matter what you are going to get different opinions from different people!!!
I did the torsion bar adjustment with the Cognito Shocks and I think my ride is definitely stiffer. I think josh is correct. You could ask 100 people and get 100 different answers. rhill is right also, it's just a matter of opinion.
Old Mar 16, 2008 | 11:31 PM
  #25
blackbear's Avatar
ORIGINAL: alphadogg
ORIGINAL: rhill20
ORIGINAL: blackbear
ORIGINAL: josh1899
Dam-it!!! I right........just kiddingthere will always be different opinions on this subject
Old Mar 16, 2008 | 11:33 PM
  #26
blackbear's Avatar
ORIGINAL: blackbear
ORIGINAL: alphadogg
ORIGINAL: rhill20
ORIGINAL: blackbear
ORIGINAL: josh1899
Oh and I'm trying to make this the longest quote in the history of this forum!!!![8D]
Old Mar 17, 2008 | 12:06 AM
  #27
alphadogg's Avatar
ORIGINAL: blackbear
ORIGINAL: blackbear
ORIGINAL: alphadogg
ORIGINAL: rhill20
ORIGINAL: blackbear
ORIGINAL: josh1899
Old Mar 17, 2008 | 08:09 AM
  #28
importkiller's Avatar
the leveling kit comes with shock extender brackets..which is why your ride stays the same...it takes the crappy stock shokcs and makes them work as if they are longer by changing they're mounting location.
the only difference in ride could be from changing the cv-joint angles...which will happen either way you lift the front end unless you have a diff relocation bracket. There aren't realy any opinions on this...it's fact...you are not changing the T-bars spring rate, your not twisting the t-bar...so there is no way your ride stiffened from the t-bar. Unless of course you went nuts and over extended the shocks or are up against the bumpstop.
Old Mar 17, 2008 | 11:49 AM
  #29
HumminNBoatin's Avatar
I am with IMPY on this one. I went through this whole dilemma on my Durango. I cranked the T-Bars to get an additional 2.5 inches andthe ride got stiff. The next week I put on Rancho RS5000's and the ride was like new again. Just crank them and save your money. My H2 has them cranked just a little to fit the 37's. And the ride is no differnet than stock.
Old Mar 17, 2008 | 10:35 PM
  #30
rhill20's Avatar
ORIGINAL: alphadogg
ORIGINAL: blackbear
ORIGINAL: blackbear
ORIGINAL: alphadogg
ORIGINAL: rhill20
ORIGINAL: blackbear
ORIGINAL: josh1899
Why stop now, at least this is new.
