LED HeadLight swap ?!
Old Nov 8, 2014 | 02:39 PM
  #31
a7m1's Avatar
Originally Posted by rsc
The color and pattern look good to me. Do you notice any flickering or pulsing of the beam from behind the wheel when scanning quickly from side to side across the light's path? I'm talking about comparing it to how LED tail lights flicker when your vision scans across them.
can you explain again, i couldn't understand you clearly
no pulse or flicker at all
before using halogen it was flickering and it seems at idle that the alternator is not quiete happy with the load from the low beam alone, so there is some vibration at idle rpm,
also rolling two+ windows down at the same time it used to dim now it doesn't seem to,
light output is stable all the time i don't remember exactly but even when cranking it doesn't seem to bother or dim (don't quote me on this) it probably has it's own circuit which handle wide voltage inputs
temperate of the bulb is acceptable it's not very hot to handle unlike halogen that seems to cause burns
Old Nov 15, 2014 | 03:49 PM
  #32
a7m1's Avatar
bump !!!
Old Nov 16, 2014 | 07:15 AM
  #33
rsc's Avatar
rsc
You know how movies are just a series of pictures, tight? They project one frame after another, and that when changed faster than about 18-20 fps appear not to be single pictures but a smooth flowing action? Your brain is tricked into not seeing the flickering images. Same with LED's, they light up by turning on/off rapidly as opposed to traditional bulbs that heat up an element to make a steady source of light. If you look at some LED tail lights, like the Cadillac CTS's, you can see them do this if you blink and look away. The light will not appear to be a solid beam.
Old Nov 16, 2014 | 08:33 AM
  #34
a7m1's Avatar
I know that some RGB bulbs that designed to give other colors than RGB
do some sort of fast switching between the colors so "our eyes" see another color.
they even get a color that is close to white from Red,Green,Blue !!!
anyways interesting finds, but can you explain how they flicker in our eyesight? really didn't pay that attention should I look and blink then look back? what do I expect to see ,will i see it off for a moment?
I can see some footage of cars startup on youtube ( not really sure if they are LEDs) but for taillights of modern cars the appear weird on camera like if you would try and capture CRT monitor using camera
Robgims
May 14, 2019 02:32 PM
fatass88
Mar 5, 2015 08:58 AM
motley1987
Oct 6, 2014 06:21 PM
crashs25
Aug 6, 2012 10:56 PM
