Know these part numbers? Wire harness clip + Delphi connector
Old May 12, 2023 | 05:00 PM
Brunob00's Avatar
Default Know these part numbers? Wire harness clip + Delphi connector
Model: 2008 H2
The wire harness clip that holds the headlight wiring to the headlight broke, and the wiring got loose and broke a small part when I closed the hood.
(A) I need to replace the wiring harness clip. Would love OEM. Anyone know what part this is? It secures to one of the three bolts that extend from the headlight. I can't seem to find it anywhere.
(B) It broke one of these when I closed the hood. Not the Delphi connector, but the black plastic piece that holds it. Any idea what these are?
Old May 12, 2023 | 06:06 PM
Originally Posted by Brunob00
Model: 2008 H2
Ambient Air Temperature Sensors
Old May 12, 2023 | 06:32 PM
Model: 2008 H2
Look here>
WIRE LOOM CLIP WIRE LOOM CLIP
Old May 12, 2023 | 07:17 PM
Brunob00's Avatar
(A) Right... all the knock off clips plug into a hole, as do most of the clips on a wire harness... this particular clip grips onto a bolt and appears only by the headlights...
(B) You got the second one! Ambient Air Temperature Sensor Assembly with 2 Terminals and 2 Alignment Tabs
Part Number: 25775833
Thanks!!
Old May 21, 2023 | 02:15 PM
Brunob00's Avatar
Bringing this back ... any one have ideas on this wire harness clip part number??
Old May 21, 2023 | 05:26 PM
****-retentive! Assembly line clips are not available? If you're unable to secure the harness with the retainers posted above, get a >>>P-CLAMP(costly):
Cheap alternative
ElectricH2
May 3, 2021 07:47 PM
Heebie3
Hummer H3T
Mar 24, 2020 12:01 AM
hummer_on_fumes
Apr 16, 2018 12:20 PM
68Thunder427
Mar 12, 2017 11:30 AM
Seafood10
Aug 11, 2016 02:29 PM
